Tip tronic shift at high RPMz
Old Jan 17, 2008 | 01:58 AM
hans127's Avatar
Is it just my car...or does anyone else's do the same thing?...Im gunning it in first gear while being in "manual mode"..and once I reach about 7 or 8k rpm the car feels like its saying.."okay, thats enough...put it in 2nd already!" It really feels like it dies down a bit and revs over and over again without much torque. I was hoping it would just let me keep going and going...but there must be some sort of limiter in preventing you from going past a certain RPM band. Anybody have an answer for this...or have a similar issue?
Old Jan 17, 2008 | 02:00 AM
HellaFly's Avatar
its called a rev limiiter that stops you from redlining and harming your engine
Old Jan 17, 2008 | 02:04 AM
Joe_Camel's Avatar
Yes, like 99.9% of all modern cars, yours has a rev limiter to protect the engine from disintegrating... but it's still a bad idea to rev the engine up to the limiter. You should shift at ~6400 RPM or so.
Old Jan 17, 2008 | 02:10 AM
hans127's Avatar
ahhh ic
should of known that most modern cars have the limiter for there tiptronic shifters. Thanks for the info!
Old Jan 17, 2008 | 02:28 AM
SDGeneralCounsel's Avatar
yeah. Plus there is a delay in shifting, so you need to shift prior to redline in order for the transmission to keep up with you. Once you get used to the delay, you will be faster than the 6MT guys. It took me a while to get the hang of it in the mountain passes and on the track because it's not like driving a MT car or an AT car, but I'm in love with the MT mode for when I am feeling mischevious
Old Jan 17, 2008 | 02:53 AM
Joe_Camel's Avatar
No problem, and remember it has nothing to do with the shifter, it's a function of the engine computer (ECU) to keep the engine from getting damaged at extremely high RPMs. You'll find this feature on manuals, autos, and manumatics of virtually every make and model.
Old Jan 17, 2008 | 03:42 AM
Vitorio's Avatar
Something realted to the topic....Racing chips can help you go in the the red line, does that also harm your engine? or the chip is designed for that?
seagrasser
May 3, 2022 09:43 AM
danielidiaz13
Engine - Exhaust
Sep 22, 2015 02:57 PM
TNRocker
Sep 21, 2015 08:36 AM
twentyeggs
Sep 11, 2015 03:58 PM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
