Vibration on steering wheel when brakes applied
Old Feb 9, 2008 | 11:21 PM
puga's Avatar
Cool Vibration on steering wheel when brakes applied
Today I noticed that when I apply the brakes the steering wheels vibrates. Is this normal? if not, what causes it? It's an 07 journey sedan with 15k miles. Has any one else experienced this? Should I take it to the dealer to get checked out? Any help is appreciated.
Old Feb 9, 2008 | 11:23 PM
B L U E S L A T E's Avatar
Honda Accord
I think there is a TSB for this... check infinitihelp.com for more info.
Old Feb 9, 2008 | 11:26 PM
puga's Avatar
What is a TSB?
Old Feb 9, 2008 | 11:33 PM
BrendanS's Avatar
another noob question not trying to hi-jack thread, what does OEM stand for again?
Old Feb 9, 2008 | 11:37 PM
Boston's Avatar
TSB= Technical Service Bulliten. Even if it's not listed under a TSB, the issue is still covered under warrantee. Go see your dealer, it's free and you'll get a loaner.
Old Feb 9, 2008 | 11:39 PM
MikeYo's Avatar
you either need to cut or change out the rotor and pads. The vibration comes from highspeed braking on stock rotors and pads, the gases have no where to go. Time for some cross drilled and slotted rotors.
Old Feb 9, 2008 | 11:41 PM
SVLRx's Avatar
it sounds like your rotors are warped... You need your rotors resurfaced but since your car is covered under warranty it should be free, if not go to a local mechanic, they should be able to resurface them for like ~50 bucks per rotor...
Old Feb 10, 2008 | 01:24 AM
Chris G35's Avatar
Looks like you have a warped rotor
Old Feb 10, 2008 | 01:31 AM
oughttoreturn's Avatar
Warped rotor, yup. 15K only, you must drive hard.
_______________
2008 g35journey/iv/st+prem&sportpkg.
Old Feb 10, 2008 | 01:55 AM
G35Now!'s Avatar
Moderation-free
There are a couple of possibilities: First, as others have said, if you have a substantial vibration it may mean your rotors are warped.
However, I noticed something interesting a while back. Since the temperature dropped into the 30s, I checked my tire pressure and aired them back up to 34 cold. Then, a few days later, temps during the day rose back up into the high 60s (gotta love Houston...). This raised my tire pressure, as the tires were warmer - Discount Tire or Tire Rack has a good description on the pressure changes, but it was likely a few pounds.
Anyway, driving on the highway after that, hit the brakes and got a light humming / vibration. "Crap, rotors are going". But, on a different road, similar situation but no vibes. I finally figured out that some of our highways have ripples that usually aren't felt. However, when your tires are hard, and by hitting the brakes and thereby putting more car weight on the fronts, you can feel them.
No brake issues since reducing tire pressure back to normal.
Good luck!
Old Feb 10, 2008 | 02:19 AM
MikeYo's Avatar
^^^nitrofill will get rid of shrinking/expantion issue.
Old Feb 10, 2008 | 10:35 AM
G35Now!'s Avatar
Moderation-free
I think you may be confusing the theoretical advantages of Nitrogen in the tires. Nitrogen helps with expansion, simply because using a specific gas instead of air means it has no moisture in it. Therefore, the expansion due to heat can be more accurately predicted.
However, unless it now defies physics, Nitrogen pressure will still increase due to ambient temperature and tire heat.
Old Feb 10, 2008 | 11:45 AM
Andy2434's Avatar
As mentioned above, your rotors are more than likely warped due to excessive hot braking sequences. Also, check the tires/wheels for proper balance.
Old Feb 10, 2008 | 12:00 PM
gary c's Avatar
Vibration will get worse......!
Yea, it's warped rotors I had this on my last Z and Nissan has a machine
that trues your rotors without removing them form the car. The actual
cause of this problem stems from two different issues, manufacturing process
when the rotors are not allowed to cool long enough. And one we can
actually do something about, never install wheels without usine a torq wrench
set at 85 LBS!
Old Feb 10, 2008 | 01:02 PM
gugarci's Avatar
15k miles and possibly needs new rotors. Is this normal on G's???
