AT not shifting to 3rd?
Old Feb 16, 2008 | 12:56 AM
G35Now!'s Avatar
Moderation-free
Anyone else having this problem? Every once in a while (like once every two weeks), my G won't shift from 2nd to 3rd. Pull the paddle like normal, but it's still in 2nd - no shift.
First time it happened, I figured I just didn't pull far enough. But since then it's happened four or five more times, and twice today I know it's not driver error now, because I've since tested the shifter and the tranny will shift if you even get the paddle 2/3 of the way back. Can't pinpoint any specific behavior, because I never know when it's going to happen. So far has only been at low to medium revs (thankfully).
I'd figure it's just a weird electronics anomaly, but if if starts happening more often...?
Old Feb 16, 2008 | 09:26 AM
EnviedG35's Avatar
If its only doing it at low revs, sounds like line pressure may be weak at that shift point. Might want to check your transmission fluid. Ive seen some cars, in general, come low from the factory. If the fluid is fine then ide take it to the dealership.
Old Feb 16, 2008 | 09:35 AM
inneedof's Avatar
ecu will override the shift command if the rpm's are not right, that is all i can think of becides checking the fluid(witch i don't think is the problem here)
Old Feb 16, 2008 | 09:57 AM
terrycs's Avatar
I assume you are in DS mode since you are up-shifting. By any chance were you doing some acceleration "testing" or practicing 1/4 mile launches?
It may be possible the ECU is doing something based on your driving habits. I'm pretty sure it happens in D mode because I've noticed my car will shift significantly higher (5K-6K range) after some "spirited" accelerations.
Old Feb 16, 2008 | 01:42 PM
G35Now!'s Avatar
Moderation-free
I am in M mode when it happens. And not launching or driving hard when it happens (maybe that's why... :-)
Old Feb 16, 2008 | 01:50 PM
CalsonicVQ's Avatar
+1....What were your RPMS when you try to shift? ECU won't let you shift if the car is going too slow for that particular gear.
Old Feb 16, 2008 | 02:21 PM
G35Now!'s Avatar
Moderation-free
Hmmm...I guess that's possible, although surprising. I usually shift the AT like I would an MT, so wouldn't upshift until at least 2 - 3k. Could be that I wasn't paying attention, and shifted too early. Will keep an eye out for that next time, thanks.
Any other ideas?
Picture Share
Feb 4, 2018 12:41 PM
RWDguy4238
Sep 30, 2015 12:13 AM
blnewt
Sep 25, 2015 01:48 PM
Hawk196
Sep 10, 2015 10:37 AM
