roof rack
From an Edmund's forum:
I thought I would post a solution since I did actually put a Yakima roof rack on my 2008 G35x. I simply bought the Yakima specs for a 2005 G35 and got the Q Towers, 48" crossbars, and 2 sets of Q35 Clips (this is the key item as they fit the G35 door/roof line perfectly). Follow the directions but you may actually need to bring the spacing between the bars and inch or so in due to the newer profile. If you run you fingers along the underside of the roof/door frame, you will actually feel purposefully build notches in the frame for the Q35 clips!
After I installed it I drove from Denver to Vail in 30-50 MPH winds with skis and a snowboard on top with zero problems. The beauty if the system is that all you have to do when you don't need it is to unhinge the Q Towers and remove the rack. That way you can avoid all the harsh ridicule on web blogs for putting a rack on "such a beautiful car"... LOL
Somebody else, I think a page or two back in this forum, posted about using Thule stuff.
