ADVAN RS...they are here
Old Mar 28, 2008 | 10:13 PM
  #61
06PlatinumG's Avatar
Pics
Here are some quick pictures that I just took
[IMG]http://i302.photobucket.com/albums/nn101/06PlatinumG/misc005.jpg
[/IMG]
Old Mar 28, 2008 | 10:18 PM
  #62
hans127's Avatar
Nice
Love the pics. thanks!
Old Mar 28, 2008 | 11:11 PM
  #63
terrycs's Avatar
Originally Posted by Gdup35sedan
Terry, every degree of camber is about 10mm in clearance.
I did a quick calculation ... the horizontal displacement for 1 degree camber is = (tire radius) x tan(1 deg) which for a 26.5" tire is roughly 6mm on the tire centerline.
It just seems really close to me ... but you do have a lot more hands on experience than I do.
hans127 ... I'm sure it will get in there given the right amount of camber. +35 would be a record for a 10" wheel. Kalvin has +38 on his 10" wheels, but he's using 255 tires.
Pics here:
https://g35driver.com/forums/media-share-v36-sedan/160731-got-my-new-20-s.html
Old Mar 28, 2008 | 11:13 PM
  #64
AlterZgo's Avatar
Gdup35sedan - When running an aggressive set up, what brand or specific model tire do you recommend that would provide the most clearance, ie. which tire brand/model has the most rounded sidewall and the narrowest tread for a specific tire size like 275-30-20 and 245-35-20?
Old Mar 28, 2008 | 11:22 PM
  #65
Gdup35sedan's Avatar
ENVautoDetailing.com
You cant have a round sidewall and a narrow tread, its either or with tires. The best and most cost effective tires for stretching are Falken 452's, but running a 245/275 setup isnt really aggressive.
Dont get me wrong, Hans' offsets are nice and what some people would call aggressive, but if you are really going to have an aggressive setup, you'd want 19x9/10 +25 all around with 235/255 tires and -2.0 degrees of camber.
The definition of an aggressive setup is getting the widest wheels you can with the lowest offsets possible and stretching the tires, combined with a little negative camber. Check out the aggressive wheel/tire setups thread in the picture share forum
-GP-
Old Mar 28, 2008 | 11:25 PM
  #66
Beebo's Avatar
wow sick rims
Old Mar 28, 2008 | 11:50 PM
  #67
Joaquin03's Avatar
Staff ALUMNI
Terry, every degree of camber is about 10mm in clearance. So with your 10" +48 and 285 tire at -0.8 camber, you could get away with a +38 with -1.8 camber and still not rub. That's 3mm more clearance than Hans' setup but he's also using a 275 tire which will give him 5mm less tire width on the outside so essentially he could run a +33 and still not rub with -1.8 camber. So with -1.5 he should be perfect with the +35 offset
-GP-
wow, that was way too many numbers and math.. props Grant..
Old Mar 28, 2008 | 11:52 PM
  #68
hans127's Avatar
haha
looks like we got an engineer major in the house!
Old Mar 29, 2008 | 12:01 AM
  #69
nope, no major here, i just understand the concept of it all. I'm majoring in architecture
but i used to be a noob just like everyone else and had no idea what offsets were. I learned most of it from Chico and then some from rijowysock and put all that knowledge together, along with observing other peoples setup's and testing out my own
-GP-
Old Mar 29, 2008 | 01:09 AM
  #70
hans127's Avatar
Gdup...
hmmm After reviewing kalvinmaui's specs and wheel pics should I consider getting a semi stretch tire and go with 265/35 19s for the rear?...or would it not look as flush having an Eibach drop. I'm just worried there might be a hideous gap. The good thing would be less tire wear bcz i wouldn't have to camber it as much, right? The H&Rs are a little lower than the Eibachs.
Old Mar 29, 2008 | 01:14 AM
  #71
You shouldnt have much of a gap with the eibach's, probably around a 1 finger gap which is perfect unless you slam it like i used to have my car.
-GP-
Old Mar 29, 2008 | 01:19 AM
  #72
hans127's Avatar
so was my last statement correct?
regarding the tire size along with not having to camber it even more. I also want to go economical here for the sake of tires...i know it'll camber regardless, but just trying to get the most minimal camber. 255s might be too much stretch...but 265s might be aright?
Old Mar 29, 2008 | 01:23 AM
  #73
with 265/35's you should be able to get to -1.1/1.2 which is barely within manufacturer specs. not much of a difference if you can get away with -1.5 on a 275/30
I set my friends coupe up with -1.5 camber in the rear and he currently has about 10k on his rear tires with atleast 50% left. So if you drive like a normal person, you should be able to get around 18k out of those falkens in the rear, if you flip them after 10k, you can get even more.
-GP-
Old Mar 29, 2008 | 01:33 AM
  #74
hans127's Avatar
ur right on...
Im gonna stick with the 275z. I didn't know u could flip tires like that.
Old Mar 29, 2008 | 01:37 AM
  #75
once the inside edge has about 25% left, you can flip flop the tires
You take the tire that was on the LR and mount it on the RR and same for the other side, now you have atleast 95% tread on the new inside and your tires last twice as long.
-GP-
