Bad Gas Mileage
Old Apr 15, 2008 | 05:58 PM
Jackooze's Avatar
Angry Bad Gas Mileage
2008 Infiniti G35x
Mileage: 800
I have read several forums and found that everyone for this type of car is getting 16-17 mpg CITY. My dashboard reads out 8.7 -9.1 mpg CITY and this is me not going over 3 rpm at all. Its a brand new car and cannot figure out why it would have such a problem. Anyone have any ideas or advice?
Old Apr 15, 2008 | 06:20 PM
djwishuwur's Avatar
I would definitely expect you to do better then that. Just as a point of reference I get about 19-21 mpg in the city in my RWD 07 sedan. Of course the X will be a little worse. Also, if you haven't already, you can do a quick check of your dashboard computer calculating efficiency by hand.
Old Apr 15, 2008 | 06:22 PM
RowanBuds's Avatar
It will improve. Just be patient. The computer isn't all that accurate to begin with, and new cars still haven't gotten all the learning under their ECU's belt. The # displayed will improve, and certainly so will the actual. I was worried about the same thing 5 months ago. Now, not so much.
Old Apr 15, 2008 | 06:36 PM
rpm&my_G35's Avatar
Don't believe the computer(s)...after 8000km mine is still way off and I have reset it many times in both locations. You should fill the tank, set the trip odo to 0, burn a least half or more of the fuel and then refill it and record how much fuel it takes to top it and how many miles are on the trip. I think you should be happier with that when you see it. If after this you still get 9mpg, then, I would say you have a problem that you should talk to Infiniti service about.
Old Apr 15, 2008 | 06:42 PM
CrazyRuskie's Avatar
I average 21mpg on my G37S & I do some spirited driving.
Wife averages 20-21mpg on her 07 G sedan and most of her driving is in rush hour traffic.
Old Apr 15, 2008 | 06:43 PM
N/A Project's Avatar
-2006 IP GT350-
Calculate it out would be more accurated.
JJ
Old Apr 15, 2008 | 06:48 PM
mIKE's Avatar
Originally Posted by Jackooze
2008 Infiniti G35x
Mileage: 800
Did you reset it when you took delivery of the car? There is a lot of testing involved during PDI, and the car is usually left runing (for a long time), as well as other times at the dealership when it is idling.
Reset it and you should be back to normal.
Old Apr 15, 2008 | 09:35 PM
Jackooze's Avatar
JJ
Thanks for the reply.
I did do a manual test . Filled the tank to full and almost at empty now and I have only 120 miles on the tank.
Old Apr 15, 2008 | 09:38 PM
Jackooze's Avatar
I have reset it countless times expecting the outcome would be different. I love everything about the car except this problem. I filled the tank to full and reset trip A to count the mileage manually. The tank is almost at empty and Trip A is at 120 miles. I thinks thats something worth worrying about.
Old Apr 15, 2008 | 09:39 PM
Jackooze's Avatar
Thats what the dealership said but who wants to wait that long and continue wasting the extra fuel until the computer adjust.
Old Apr 15, 2008 | 10:33 PM
Lemodular's Avatar
sounds unusual to me...almost like you're in the wrong gear. I get pretty much 20+ mpg since day one. I can get a touch less (like 18-19) when driven hard. It is true that the milage should improve slightly as the engine wears in but only a couple of mpg's.
If you say you stay under 3K rpm and are still getting poor milage, I would at least take it to the dealer take a look at it. BTW, what gas are you using?
Old Apr 16, 2008 | 08:23 AM
Jackooze's Avatar
ONLY 93
Old Apr 16, 2008 | 11:49 AM
07GraphiteV36's Avatar
I get 25-28 hwy, and 17-20 street, in D. If you leave it in DS alot or use manual mode all the time your mileage will go to like 12 city, 19hwy.
Old Apr 16, 2008 | 12:27 PM
B L U E S L A T E's Avatar
Honda Accord
Ah.... another gas mileage thread.....
How many more of these do we really need?
Old Apr 16, 2008 | 01:18 PM
CDN_Drew's Avatar
What's your highway cruising speed to get 25-28hwy?
