License Plate Solutions
Apr 17, 2008 | 01:00 PM
For my fellow Ontarians, if you haven't seen it yet there is a petition to rid ourselves of the front license plate
http://www.ipetitions.com/petition/Ont_Front_Plate/
This is from an old post in the Canada forum so don't repost the link as a new post please.
Reply 0
May 2, 2008 | 01:07 AM
anyone know where to order the stillen lp bracket kit. are there any sponsors on the site that sell it
Reply 0
May 2, 2008 | 01:24 AM
Back in the day, when I got a ticket for no front lic plate and I had to take my car in for inspection, I used double stick tape so that I wouldn't have to drill into my front bumper. It held the lic plate extremely well. That stuff is super strong. If industrial grade double stick tape works for stuff like spoilers and rear wings, holding a small lic plate is no problem. I think I drove around w/it for 2 months or so and it held on firmly - even after I washed my car a few times.
Reply 0
May 20, 2008 | 10:59 AM
Quote: My solution on my Z4M
Tried that in MD, cops still issue tickets if they notice (they can't bounce their radar off of it cause it's not metal )
They are also quick to issue a citation for a front tag in the dash, and that just adds attention.
You can also be issued a citation (in MD at least) if your plate is too low/facing the ground/mounted in a non-OEM location. I believe the citation is 'Improperly/unmounted Registration Plates' and carries a fine.
Reply 0
May 20, 2008 | 11:13 AM
why do some states require this law?
Reply 0
May 20, 2008 | 01:31 PM
Here's my $60 solution for a front license plate:
It's only $60 in MD if you get pulled over. Unless of course they give you a repair order, of which I would make the arguement that there was nothing to repair in the first place; no brackets were originally installed. Either way. Check your State law; then do what you want. Better than speeding!
Reply 0
May 20, 2008 | 02:24 PM
www.infinitiplate.com sells front plate adapters that use the tow hook, but it says coming soon for the 07-08 G sedan and G37. It might be worth sending them an email to find out more though.
Reply 0
May 20, 2008 | 02:42 PM
Quote: It's only $60 in MD if you get pulled over. Unless of course they give you a repair order, of which I would make the arguement that there was nothing to repair in the first place; no brackets were originally installed. Either way. Check your State law; then do what you want. Better than speeding!
I agree, and it seems as if I get bothered a LOT less now that I have the G. I don't have an MD front tag, I have a JDM front plate. Even so, that's still not complying with the state law, but the cops that have seen it just ask questions about where it's from Never gotten a ticket for it though, and had about 10 in the past cars I've owned.
Reply 0
May 20, 2008 | 08:00 PM
I just picked up my new G35 last weekend and it had a front license plate frame in the trunk and I live in AZ with not front plate requirement.
Reply 0
May 20, 2008 | 09:01 PM
Quote: Here's my $60 solution for a front license plate:
Attachment 89780
What kinda front grille is that? Sorry, new to the forums lol.
Reply 0
May 20, 2008 | 09:02 PM
Here in Vegas, I'm pretty sure you only need to run a front plate on a car that was equipped with brackets from the factory.
Reply 0
May 20, 2008 | 09:16 PM
Doesn't Stillen make a no-drill kit?
Reply 0
May 20, 2008 | 09:25 PM
Quote: Doesn't Stillen make a no-drill kit?
Yup
Reply 0
May 21, 2008 | 12:35 AM
there is another option nobody has said
There are JDM license plate bracket mounts that will mount the plates to a surface parallel (and facing) the ground. This way you drill the holes at a place that won't be seen - i.e. you can take the plate and bracket off and no holes will show
http://passwordjdm.com/PasswordJDM-L...or-P973C0.aspx
Reply 0
May 21, 2008 | 07:13 AM
  #30
Quote: What kinda front grille is that? Sorry, new to the forums lol.
It's called a one-off! I posted another thread a while ago.
Reply 0
