Performance mods list for G35 sedan
Old Jun 1, 2008 | 10:40 PM
earth0's Avatar
I know made in China.Cheap!! i was planing to put on my Door Step!!
Just Email and ask this guy that you need T10 License plate XENON light for G35
http://cgi.ebay.com/ebaymotors/JDM-B...spagenameZWDVW
Old Jun 1, 2008 | 11:41 PM
Wes_888's Avatar
hey eartho - any instruction threads on replacing license plate lights out there that u know about?
or maybe u can just tell us? :P
Old Jun 1, 2008 | 11:53 PM
earth0's Avatar
Yeh,Very easy!!!!!! total is 2 Bulbs
1) Look under your License Plate Light.There is a hink on the right end of each light.
2) Push it all the way to the Left end and push down!!
3) Pop out the Light Cover by Pushing the Pins
4) Replace it with New Bulbs.
Hope this help!! Will try to DIY Picture tomorrow.
earth0's Avatar
[QUOTE=Wes_888]hey eartho - any instruction threads on replacing license plate lights out there that u know about?
earth0's Avatar
Old Jun 1, 2008 | 11:57 PM
Wes_888's Avatar
awesome! thanks! im gonna order some of these lights then! :P
Old Jun 2, 2008 | 12:01 AM
Wes_888's Avatar
Im assuming changing the parking lights is not this simple..
you have instructions for that too? hehe
Old Jun 2, 2008 | 12:05 AM
earth0's Avatar
You mean Reverse?
Old Jun 2, 2008 | 12:11 AM
Wes_888's Avatar
You mean Reverse?
reverse? im lost.
Old Jun 2, 2008 | 12:13 AM
earth0's Avatar
What i meant is R (reverse)
Sorry if i did not currect you.
Parking Citly light? Corner locate on top of HEADLIGHT?
Old Jun 2, 2008 | 12:19 AM
Wes_888's Avatar
Actually I meant the daytime running lights
Old Jun 2, 2008 | 01:18 AM
Phalanx's Avatar
What budget you have?
Stillen Exhaust approx $1040-$1150
Stillen hi Flow Intake Short Approx. $331/ Long Tube Approx $415
Impul ECU $2700
Brake??
Keep in mind you are driving Infiniti Not EEClipSS!!!
Choose yourself to fits your budget.GL
Ok, what does Impul ECU do? How much power should I expect from that load of money ?
Old Jun 2, 2008 | 08:47 AM
earth0's Avatar
For Parking CityLight.
1) For Left Side..Turn the Wheel to the Right
2) For Right Side..Turn the Wheel to the Left
You need to follow this instruction.For just changing Parking Citylight you DO NOT have to take off the wheel
Just loose the 3 lock pins and open up.
https://g35driver.com/forums/v36-diy/204234-diy-philips-6000k-ultinon-install.html
Next is to locate the bulb that plug into the back of Parking light and loosen it
by turning to the left and pull it out.
Repeat the same.
GL
Old Jun 2, 2008 | 09:04 AM
Wes_888's Avatar
https://g35driver.com/forums/showthread.php?t=204234
Repeat the same.
GL
awesome! thanks man :P
Old Jun 2, 2008 | 02:59 PM
  #30
ugaexploder's Avatar
hey earth, would i follow your instructions for just cutting the wheel left or right in order to change the turn signal bulbs too? thanks man. you're the lightmaster
You have already rated this thread Rating: Thread Rating: 2 votes, 4.50 average.
