Rear A/C Vents?
Old Jul 16, 2008 | 08:02 PM
rpm&my_G35's Avatar
Originally Posted by G35Now!
Hiya Mike:
One thing to add, the G can roll the windows down with the remote (all for with Premium pkg, front two without) by holding down the unlock button. This lets some of the heat out before you get in, which helps a surprising amount.
What I can't figure out is why the G is incapable of rolling them down all the way without multiple button presses...freakin' annoying.
Thats weird...my windows all go down all the way on the second push/hold of the unlock button.
Old Jul 16, 2008 | 11:02 PM
G35Now!'s Avatar
Moderation-free
That's interesting: Wonder if it's a) a problem with my remote(s), or b) something Nissan fixed in the new remotes EDIT:>> Yes, I still have the original '07 remotes. Getting my remotes swapped next time I go to the dealer, maybe that'll fix it
Old Jul 17, 2008 | 07:51 AM
soundmike's Avatar
That's interesting: Wonder if it's a) a problem with my remote(s), or b) something Nissan fixed in the new remotes. Getting my remotes swapped next time I go to the dealer, maybe that'll fix it
Do you still have the original remotes? Mine was apparently already exchanged (iKey recall), so perhaps the new keys do it OOB.
Old Jul 17, 2008 | 06:20 PM
rpm&my_G35's Avatar
Just a thaught.
Is it possible that a weakened battery is the culprit?
A quick button push would not require much juice but holding and sending the signal for ~5 seconds may be too much for a weakening battery.
Old Jul 18, 2008 | 03:49 AM
G35Now!'s Avatar
Moderation-free
Just a thaught.
I wondered the same thing, but replaced my remote battery for the second time a couple of weeks ago. No difference
Motivation to get out to the dealer and get the remotes changed tho.
Old Jul 18, 2008 | 10:06 AM
sredish's Avatar
my windows also go down with a second hold of the button only.
Old Jul 18, 2008 | 01:35 PM
txg8r's Avatar
Interesting - I have an 08 with the new remotes - and when I hold the remote button down - mine seem to stop with the fronts about 2/3 of the way down, and the backs about halfway......
I also thought of the weak battery but have not yet tried to replace it. Another possibility is weak signal from the remote itself. I'll have to get a new battery (or try the other remote) and see what makes a difference
edit: forgot my other point. The vents under the seats are likely connected to when the vents are set to the floor or mixed settnigs........ so not sure how much AC gets back there without the rear AC vents from the console. The dash vents do blow fairly strongly on the higher settings - so if you aim the vents straight back they likely get more air to the back then what comes from the console vents
like you said, it's not a deal breaker, but it does make it nicer for folks in the back seat in the summertime
Old Jul 18, 2008 | 02:08 PM
rpm&my_G35's Avatar
The downsides to using vents under the seats for rear passenger A/C:
1. Cold air doesn't rise
2. Your feet freeze and you can't shut it off, the driver controls them.
Old Jul 19, 2008 | 07:57 AM
soundmike's Avatar
The under floor vents are for heat only.
Old Jul 19, 2008 | 08:07 AM
AesonVirus's Avatar
My windows have always dropped all the way down with a single push of the button.
I just tried it again yesterday after a round of golf and sure enough, the windows stopped halfway and I had to hit the button again to drop them the rest of the way.
It's just a break in the signal... For whatever reason. Weak battery, maybe.
Old Jul 19, 2008 | 10:56 AM
sredish's Avatar
I'll rephrase this. I click the unlock, then have to click and hold the second time for the windows to go down. If I let up on the 'hold', then the windows will stop. So, I have to hold the unlock until the windows are all the way down.
jsimonk
Dec 22, 2023 03:49 PM
champppy
Mar 31, 2020 12:25 PM
R1 Autoworks
Exterior-Vendor
Jul 3, 2019 07:16 PM
baker2795
Sep 2, 2015 06:00 PM
Rehman2009
Jul 27, 2015 03:23 AM
