2008 G35 Change Digital Clock Time
Old Oct 2, 2008 | 12:06 AM
bobolee's Avatar
Hi all,
I just took my car into service to fix my radio programming technical bulletin and they wiped out my time on the digital clock. How do I change the time of the digital clock?
Also, I think they broke my traffic too....Thanks in advance.
Old Oct 2, 2008 | 01:01 AM
kool_yaar's Avatar
YOu con go to the settings>display>clock(or something lie that) option to set the clock. And what do you mean by "they broke my traffic too..." :0
Old Oct 3, 2008 | 11:07 AM
fieldsie's Avatar
Is the digital clock only on cars with Nav? I have an '08 g35x with premium but not Nav. Would love to have a digital clock in addition to the analogue.
Old Oct 3, 2008 | 01:44 PM
CyberSky's Avatar
You can go to Settings > Clock to turn the digital clock on or off, set the format to 12-hour or 24-hour, etc., but you can't actually set the time since it's part of the GPS signal and is updated automatically. And, yes, that means the digital clock is part of the navigation package.
Old Oct 3, 2008 | 02:19 PM
TN G35S's Avatar
I was wondering! I just kept thinking....there's no way I've had this car a month and not found the digital clock
Old Oct 3, 2008 | 10:04 PM
SVLRx's Avatar
i had a loaner for the past week, and was wondering where the hell the clock was.... Finally figured i only had it b/c i had Navi. Lucky i have navi too, b/c if i had to glance down in traffic to "read" the analog clock, i would rear end someone b/c i'm slow
Old Jan 29, 2009 | 09:44 PM
waikeing's Avatar
I am new and I have the digital clock with wrong timing on it. There is no Clock under Setting section since my G35 does not have Navi as an option. So my question is, without Navi, how would I adjust the dig. clock??? seems cant find a way to do it.
Thanks for the help.
Old Jan 29, 2009 | 10:57 PM
Csquared's Avatar
HOw do you have a digital clock and no NAV?! Omg I want!
Old Jan 29, 2009 | 10:58 PM
carz's Avatar
you cant change the time, but you can retard or speed up the time...its weird
Old Jan 29, 2009 | 11:00 PM
Csquared's Avatar
What?! So you can't change the time but you can change how long it'll take for it to change 1 minute?
Old Jan 30, 2009 | 05:44 AM
DigMy35x's Avatar
Check out 4-17 in the manual. IF you have the clock you can offset adjust the clock so if you are always running late, you can add a bit of time to make it seem 5 minutes later(for example).
For some reason Infiniti has the manual protected so I can't cut and paste the text anymore (!!!
Hope that helps!
Jay
Old Jan 30, 2009 | 04:18 PM
TheIvoryG's Avatar
Am I the only one that doesn't like the digital? Turning that off was one of the first things I did. I just feel like Infiniti is known for that analog, so I'm going to run with it.
Old Jan 30, 2009 | 05:31 PM
AesonVirus's Avatar
+1
I was so happy when I found the option to remove it from the screen. I never liked it.
Old Dec 28, 2010 | 12:02 PM
Gregger's Avatar
I can't for the life of me figure out how to set my analog clock. It's 5 minutes slow.
Old Dec 28, 2010 | 12:16 PM
Hotdawwgman's Avatar
^ lol
