Spacers with OEM wheels and vibrations in the cabin
Old Oct 7, 2008 | 10:04 PM
hans127's Avatar
Lately me and my sport tuning mechanic have been going crazy trying to figure out why my car has been vibrating at the steering wheel as well as with the passenger seat while driving between 55 to 70 mph. Im not sure if any other OEM wheels have this issue, but if you have an 07 or 08 G35 Sedan Sport with G37 coupe wheels and have the sudden interest in putting hubcentric spacers on your car, it will vibrate!!! Its not your wheel ballancing...and its not your allignement!...It simply comes down to one thing, and thats the type of lug nuts you put on your car. Please dont make the mistakes I made in the past by going through the loop holes in figuring out this annoying issue. Hope this helps others with the same problem
Old Oct 7, 2008 | 10:13 PM
ckp's Avatar
ckp
so what kind of lug nuts should we get to avoid the vibration??
Old Oct 7, 2008 | 10:52 PM
archie's Avatar
i do not believe the spacers are the cause of the passanger seat vibrating/shaking at highway speeds. in my car, as well as with every other g35 sedan i have driven so far, the passanger seats vibrate at highway speeds as long as no one is sitting in it.
Old Oct 7, 2008 | 11:17 PM
SVLRx's Avatar
my passenger seat doesn't vibrate at all at any speeds.... though my rear deck rattles at certain speeds when going over little imperfections in the road...
Old Oct 7, 2008 | 11:18 PM
808MIKE's Avatar
I have the G37 19's on my G sedan also. But have no spacers. and used the Lug nuts from my Stock 18's. and everything is fine at any speed. But I don't have spacers like you have. I think the rims sit perfect without the spacers!? Why do you want to make the 19's come out more? I think it would stick out too much with spacers?? But thats just me.
Old Oct 8, 2008 | 12:17 AM
SDGeneralCounsel's Avatar
get an alignment...
Old Apr 20, 2009 | 09:59 PM
G35n2ziast's Avatar
i have an 05 coupe with oem 18s. no spacers.
the same thing was happening before.
It was vibrating everytime i go over 60mph.
the vibration goes in a sequence, every 2 secs it vibrates.
I installed the wheels my self, when i switched from 19s to stock 18s.
I went to the tire shop and when i (again) was trading with another oem 18s but powdercoated gloss black, after the switch it doesnt vibrate anymore.
So i figured that it must be the need of tire balancing or maybe the time when i installed it myself, the front tires does not match the tire rotational(arrow) on the rears.
Old May 27, 2009 | 09:45 PM
cmo23's Avatar
umm- did we ever figure out what lugs the OP switched to resolve the problem??
Old May 28, 2009 | 05:10 AM
infinitipearl's Avatar
+1. Hans, any input would be greatly appreciated on this. I have Ichiba v2's on my stock sport 18"s and am getting crazy vibration (you can see my recent post in the tech section) from about 50-70mph. Had a balance and alignment to no avail.
Old Apr 26, 2011 | 10:31 AM
Deezflip's Avatar
*bump*...anyone else with spacers, recently balanced, recent alignment, have hubcentrics, new tires, new wheel bearings, torqued and re-torgued all lugs....still get the shakes?
I'm beginning to think it's the compression rod, or the lower control arm bushings.
CJay
Aug 1, 2015 03:57 AM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
