Problems @ 3000rpm 1st gear, can anyone help
Old Oct 22, 2008 | 01:05 AM
usahockey83's Avatar
The problem is slight, but when I floor it from a stop my AT seems to take an extra half-second to realize I'm flooring it before I get the fast revs. It kinda goes up to 3K rpm at a normal acceleration speed, stops, then revs quickly all the way to 7-8K rpm before shifting, which is the speed it should go up all the way, not just the second half. Is it just me, or is this common? Is there a serious problem or do I just need to do a little change? I tried it in DS mode and it didn't seem to help too much either. Does anyone have any advice or suggestions? Thanks in advance.
Old Oct 22, 2008 | 01:08 AM
Canadian's Avatar
Canada, eh?
Is this with VDC on or off? You're not holding the brake when you're hitting the gas are you?
Old Oct 22, 2008 | 01:48 AM
Csquared's Avatar
I don't know i think it's the ECU, someone correct me if i'm wrong, but when i reset the ECU and went for some hard runs, it always revs hard, but when i drive around a lot conservatively the throttle is much more retarded. I get smoother starts etc instead of the jump off the line reaction. I'm guessing you drive around town a bit so your ecu is just trying to save you gas. No idea for me it's not that much of a lag though.
Old Oct 22, 2008 | 07:55 AM
snowcrossmxz's Avatar
valve lift doesn't kick in until then, maybe thats what ur feeling?
Old Oct 22, 2008 | 08:00 AM
G35Now!'s Avatar
Moderation-free
+1 on VDC - you're going to get some wheelspin, with VDC on the G will hesitate for a split-second until the tires stick.
Old Oct 22, 2008 | 02:08 PM
silverG2007's Avatar
Sounds like VDC.
But, even with my VDC on, if I floor it, the car takes off before 3k rpms and only hesitates when the VDC comes on.
Is this a new problem?
cmesidewayz
Sep 29, 2015 09:28 PM
TrillO.G.35
Sep 5, 2015 02:06 AM
Jnm07
Sep 5, 2015 01:16 AM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
pasjr1972
Sep 1, 2015 10:17 PM
