Shark Fin Antenna + Roof Overlays! How To?!
Old Mar 17, 2010 | 10:59 AM
dohturdima's Avatar
Originally Posted by bat6wc
bringing this back. looking to find out how to remove the shark fin.
anyone have a link to that DIY?
https://g35driver.com/forums/audio-v...r-removal.html
I have the stock Sirius antenna that came with Sirius Kit (the boxy type) that I would like to replace with a shark fin. Don't know whether it will improve reception (which isn't great), but the aesthetics would be better. The install seems fairly straightforward, although the DYI is for a previous generation G.
Old Mar 17, 2010 | 11:17 AM
bat6wc's Avatar
Thank you
Old Mar 17, 2010 | 11:32 AM
rpm&my_G35's Avatar
I recall seeing a DIY Fin install on a 2nd Gen sedan, with Pics. It was a couple years ago. He removed the head liner and drilled through roof. Very clean install. I will try to find it.
Edit:Never mind - it was the same DIY you posted the link for
Last edited by rpm&my_G35; Mar 17, 2010 at 11:38 AM. Reason: It was the same Fin install in your link - embarrassed
Old Mar 17, 2010 | 12:13 PM
dohturdima's Avatar
I have the factory Sirius unit installed (got a few weeks after I bought the base G 2.5 years ago). My Sirius antenna is mounted midway on top of my rear window (right next to it), and it is the same as this kit:
http://www.g35parts.com/G35-Sedan-Fa...p/siriushp.htm
I was wondering whether it was possible to install a shark fin instead of that boxy antenna. The answer is likely yes, but I don't see myself wanting to drill a hole in my roof just to install a shark fin, which may look better but probably will not improve reception since my antenna is already sitting outside on top. I would be much more inclined to consider a shark fin install if I was having reception problems due to sat antenna being inside the car.
Old Mar 19, 2010 | 06:05 PM
bat6wc's Avatar
i wanna know if I can go the other way and remove the shark fin with an alternative to leaving a hole in my roof.
is there a flatter cover?
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
g.spot
May 9, 2016 10:54 PM
DEMoLITIoN
Apr 20, 2016 06:57 PM
R350k5
Lights
Jan 12, 2016 09:22 AM
