GT Spec is coming through for us!
#91
on
Hey quick, Q... installed my GTSPEC FSTB last night!
Problem:
I couldn't tighten the Allen wrench portion of the vertical adjustment bolts that secure the brace bar to the mounts.... anyone know what size allen wrench these bolts take?
It was a lot bigger than my standard 1/4 Allen, is it more like a 5/16th or bigger?
Here is a link to the bolt I'm talking about.
http://www.gtspec.com/images/forgedend-gtspec-1.jpg
I need to go to the store and buy an allen wrench big enough to torque it down a little bit more than just my hand tightening method.
Initial impressions of FSTB:
Much better front handling when going around corners at higher speeds (30 mph +) is where you really notice the difference, and I only have the FSTB. Seems like the front is planted, I'm thinking about getting the tanabe front sway bar and ditching the Stillen front sway bar. I think the Stillen was/is good over stock but not stiff enough for my liking.
thanks!
Problem:
thanks!
#92
#94
Here's the Allen / Hex bit socket that I use:
http://www.sears.com/shc/s/p_10153_1...bit+socket+3/8
But this one should work too:
http://www.sears.com/shc/s/p_10153_1...yword=8+mm+hex
#95
No tune yet.. Unfortunately the tuner I was going to never was able to rear my ECU, so I'm gonna try a different tuner this week and see if they have any more luck with it. Thanks for asking, though.
#97
#100
#102
thanks!
thanks!
#103
