OEM Front Lip Questions...
Old Dec 26, 2008 | 12:16 PM
JP1080INC's Avatar
for those of you who have the OEM front lip i got a few questions for ya.
how hard was the install?
did you have to use some sort of tape or does it have to be screwed on?
also where did yall get it from and where is it the cheapest?
thanks!
Old Dec 26, 2008 | 12:23 PM
ugaexploder's Avatar
i'm pretty sure it only uses 3M double sided tape...the install should be fairly easy...just clean the bumper really well and use a 3M adhesive promotor to wipe down the area that needs to be stickied...line it up with the bumper and slowly strip the 3M while it's fitted properly...should be a piece of cake
Old Dec 26, 2008 | 01:00 PM
kool_yaar's Avatar
Actually you also have to drill ~10 holes plus the 3m tape, but it is pretty easy, many newbies to car mods have done this pretty easily, so if you know how to to use a drill you should be set in about 30-45mins tops
Old Dec 26, 2008 | 07:32 PM
G35xQX1's Avatar
The install didn't look to bad to do (I had it done by a reputable body shop). It's better if you have 2 people to install it. One to drill the holes and one to hold the spoiler.
Old Dec 26, 2008 | 08:23 PM
mishmosh's Avatar
-apply templates
-drill holes
-put on spoiler (will pretty much hold itself up when ends snap into wheel wheel)
-align spoiler to marked line and remove backing from tape
-apply bottom screws/clips
total time 1 person: 1 hour (max)
difficulty level: 2/10
Old Dec 26, 2008 | 09:27 PM
earth0's Avatar
Originally Posted by mishmosh
-apply templates
-drill holes
+1000000 Agreed with all this instruction.
Old Dec 26, 2008 | 11:22 PM
Csquared's Avatar
Dude I wish you lived near me earth0 lol.
Old Dec 26, 2008 | 11:30 PM
JP1080INC's Avatar
thanks guys
Old Dec 27, 2008 | 08:21 AM
earth0's Avatar
Hey! You back? Have you try it?
Old Dec 27, 2008 | 03:19 PM
Csquared's Avatar
not back yet, miss the car and i want to try it bad.
Old Dec 27, 2008 | 03:54 PM
AlterZgo's Avatar
It's not hard to just slap it on there. However, if you are interested in getting it to match up w/ the lines on the template, it's a little difficult - especially w/ 1 person - because as you're trying to hold the lip in place, it's under tension and you're trying to pull the cover off the tape, while at the same time, trying to prevent it from sticking in the wrong place and also trying to prevent the thin rubber weather seal strip from folding over on itself.
If I wasn't worried about getting it aligned just right, it would've probably taken me 1/2 the time.
Old Dec 27, 2008 | 10:25 PM
SVLRx's Avatar
I took my time to make sure it was perfect. Took roughly 1.5 hours with 2 people. using the template, and taking time out to figure out how i was going to cut the ~1 inch holes in the bottom of the bumper.
So yea, ~15-20 min to align the templates just right
another 20 minutes to drill the holes (took me that long b/c i used a dremel to make the BIG holes)
then another 15 minutes to make sure it's aligned well, and the little weather stripping is perfect and not folded under.
then ~30 seconds to pull off the tape...
Old Jan 1, 2009 | 01:00 AM
DrGeeMD's Avatar
I just ordered a front lip and am expecting in a few days. Do you have to jack the car up to drill the holes?
Thanks
Old Jan 1, 2009 | 08:58 AM
earth0's Avatar
Thanks
NOP!! Just follow the instruction that came with the OEM.and you'll be fine.
Old Jan 1, 2009 | 11:06 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
Thanks
No, you don't have to, but it does give you a little more space to work with.
I put my front on jack stands..... takes 5 extra min but IMO makes it easier.
...you also have to crank the wheels back & forth to full lock to drill one hole in each wheel well.
