Modding on a budget.need opinions.
Old 01-06-2009 | 09:43 AM
5u30five's Avatar
Tough times calls for budget mods. which wheels to get? 19 oem m45 rims or 19 oem rays rims. need everybody's input. it will go on my 2007 IP sedan. thank you guys...
Old 01-06-2009 | 10:40 AM
G35driver101's Avatar
i say the m45 wheels..
Old 01-06-2009 | 10:55 AM
titan13qb's Avatar
i'd honestly say 19 g37 rims...they are so sexy...but good luck with the pick
Old 01-06-2009 | 11:38 AM
ugaexploder's Avatar
M wheels definitely
Old 01-06-2009 | 11:40 AM
Csquared's Avatar
looks go m45 for performance rays. So much lighter because they are forged, tougher too.
Old 01-06-2009 | 11:55 AM
2008G35XSinMD's Avatar
+1 on M45 wheels. I have them and love the look. Also what model G35 do you have? If you have an X then I would stick to the M45 wheels otherwise you'll have different size wheels in the front and back.
Old 01-06-2009 | 04:04 PM
loudog2's Avatar
I kinda like the 370Z rims also
Old 01-06-2009 | 05:15 PM
TheIvoryG's Avatar
I too vote for the G37 wheels.
Between Rays and M45 I personally think its a toss up. I had the same dilmena when I first bought my car, and I found a great deal on the Rays so went with those.
Old 01-06-2009 | 05:22 PM
Jeff92se's Avatar
Red Card Crew
Rays if it's wheels only. Or if packaged, I'd go G37 19s. They stock tires sizes would be closer to the oem sedan sizes for 08+ HR powered sedans?
Old 01-06-2009 | 09:58 PM
greg_atlanta's Avatar
2008 G35 Journey Sedan no sunroof
Cheapest and most effect mod is better tires for your existing rims. Bigger rims are mostly cosmetic -- and can hurt performance if they're heavier, or if they have generic all-season tires.
Old 01-06-2009 | 11:20 PM
AlterZgo's Avatar
I second this recommendation. The other plus w/ 370Z 19" rims is the fact that they come with 275-35-19 and 245-40-10 tires.
Old 01-06-2009 | 11:28 PM
supracrazy's Avatar
G37 19's hands down
Old 01-07-2009 | 12:26 AM
5u30five's Avatar
what if i throw a volk TE37 19 x 8.5 +35 in gunmetal into the mix. keep in mind it will go on an IP sedan. thanks for all the input guys. this will be my first real mod so i wanna do it right.
Old 01-07-2009 | 01:11 AM
mishmosh's Avatar
If you are thinking economy, the m45 rims are nice because you can run the same size tires and rotate them as needed. As mentioned, they are fairly heavy though. I have them and run 235/40/19s all around with 15mm spacers. You can definitely feel the performance loss but I'm not exactly going to the track either.
Just beware when buying m45 rims. A lot of 1st genners have been using them and run very low profile tires--many are bent without it being obvious. Unfortunately the set I got from another forum member here had this problem--should have known better when he did not want to sell just the rims but tires/rims together.
Old 01-08-2009 | 09:21 AM
5u30five's Avatar
bump...help guys.
Quick Reply: Modding on a budget.need opinions.
