Foglight/Interior Light Replacements?
Morning Kids - I know there is a Tech Section, but I haven't been able to find much information on the G37 so far (must be cuz us owners are so exclusive).
Shennanigans aside, I'm looking to replace the yellow fog lights and possible some interior lights in my 09 G37S. I'm thinking blue would be sweet, but would be ok with something with a blue-ish tint if need be (not sure if blue is legal; too cop-like).
Has anyone done any lighting replacement on their 09 G37s? If so, any recommendations or advice would be greatly appreciated. Thanks much.
i'm not sure bout the fogs but i think u can get leds from superbrightleds.com or like ijdmtoy.com...i'm pretty sure everythin on the 37 sedan is the same as the 07+ 35 sedan so u could probably check that section of the forums out instead
yep just what G35plusKB24 said, all the lights are the same, I changed all my interior, Licence plate, and parking Lights to LEDs, and they look way nicer.
I purchased the following
For lincence plate & parking lights 4 bulbs
http://www.v-leds.com/Shop/Control/P...id/0/SFV/32481
The rest are from https://www.superbrightleds.com
Bought 3 WLED-x5 LED Wide Angle LED bulb for Map light and trunk light.
4 WLED-x4 LED bulb for the doors, and back illumination.
I want to repalce my fog lights and based on the link to sylvania the HB4 bulb would be replaced by the 9006SU. I assume these do not run hot as I do not want to mess with any wire harnesses! I had the Ultra's on my Maxima and I did like the whiter lighting better!
9006/ HB4,
9003/ H4,
ketchup/ catsup...
If you care about how hot the bulb burns, then check the specs before you make your purchase. Whether it's labeled 9006 or HB4 isn't going to matter.
9003/ H4,
ketchup/ catsup...
Philips makes a bulb called Blue Vision. Philips bulbs have one of the highest ratings available from what i've researched. They are normally priced around $35 or 40 bucks but are around $10 at this site.
http://www.bulbs.com/eSpec.aspx?ID=1...f2=Light+Bulbs
Hasanbaloch
Feb 29, 2024 08:45 PM
Micale757
Lighting
Apr 8, 2020 10:46 AM
Luisgalvan33
Jul 19, 2018 08:16 PM
Luisgalvan33
Jul 28, 2015 05:37 PM
