Add more base to original sound G35 sedan
Old Mar 5, 2009 | 08:37 PM
vietkool's Avatar
Question Add more base to original sound G35 sedan
I got a 2008 G35, sedan few months ago. Premium sound system installed but kindda lack of base. I'd like to add just more base to the system.
I think about get me a 8" bazooka w/ built-in Amplifier (150 watts RMS). can I just tap of the two rear speakers to plug to the bazooka? does it make the original speaker damage ?
is anyone here done this before please give me some suggestion
thanks
VK
Old Mar 6, 2009 | 12:59 PM
joes954rr's Avatar
Rear Woofer "Vent" Fix
My suggestion would be to pull the rear woofer.
Reason:
Its in the perfect location, and isn't capable of that much bass. If you're going to build a box, or do a bazooka tube (doesn't matter), let that bass bounce around in the trunk and amplify, then come out the rear deck into the rear window and BOOM right into the car. It's the best possible way to get bass into a trunk-setup car. The rear woofer would most likely get damaged from all the additional backpressure of a trunk woofer, so I would pull it out.
The factory grill and etc should be retained for that stock look and feel, plus you can return it back to stock later if you change your mind, sell the car, etc. I would do a nicer quality 10" woofer, maybe a custom box with .5 - .75 cu ft (depends on the woofer requirements). Bass tubes are cool, but an 8" will do more than the stock setup, but I think you'll find a 10" would be the magic trick.
Do not doubt the power up an upward firing "vent" from a trunk. Sounds incredible with the trunk lid closed. Very clean sound.
Old Mar 6, 2009 | 01:42 PM
vietkool's Avatar
so your suggestion is if I use the tube like bazooka/amp (easy to install) I should use the 10" one and remove the stock base (located in the middle rear one) be cause the air pressure may damage the stock base since it present there didn't do any good.
if so can I use the signal from the stock base wire to the tube base ? cuz I know there is a small amplifier to drive the stock base as well.
Old Mar 6, 2009 | 01:43 PM
ketchupfreak's Avatar
Reason:
DIY to removing the rear deck sub?
Old Mar 7, 2009 | 01:33 AM
g35_JV's Avatar
pics of this setup would be nice ;-)
Old Mar 7, 2009 | 03:27 AM
popcornten's Avatar
its bass, not base...
Old Mar 7, 2009 | 09:41 AM
vietkool's Avatar
thanks for correction. I didn't pay attention on the word
Old Mar 7, 2009 | 12:10 PM
mishmosh's Avatar
So who has removed the stock rear center woofer? Can it be done from inside the trunk or do you have to remove the rear seats and rear tray.
Old Mar 7, 2009 | 12:17 PM
Hotdawwgman's Avatar
Remove the rear seats and the tray will be the right way to do it... It isnt that hard, just dont snap any of the clips, or its rattle city!
Old Mar 7, 2009 | 02:02 PM
kool_yaar's Avatar
rattle will be insane with any bass upgrades without proper padding and insulation, i ended up removing my 2 10" type-R so think about it before doing it....
Old Mar 7, 2009 | 02:56 PM
popcornten's Avatar
I have a really nice Alpine system that I had in my bemer but didn't install in my G if anyone's interested?
I'll cut you a deal, it's just taking up space
mjfenix
Aug 17, 2017 05:49 AM
poktanG35
Engine - Exhaust
Oct 26, 2015 03:32 AM
laksjd84
Jul 24, 2015 05:12 PM
cyrus32
Jul 18, 2015 06:22 PM
