Bluetooth cuts on and off
Old Apr 15, 2009 | 12:16 PM
chairman25's Avatar
I've searched and do not see anything on this issue. I have an 08 G35XS with Nav, and the bluetooth cuts in and out, I can be on a call outside of the car, I get into the car and start it and bam, I cannot hear the call. The other person can hear me. I live in Metro Washington, DC so the area is not the issue (plenty of cell towers, etc).
This happened to me again this morning on my way to work. I will admit that it may be the phone (LG 8100) and yes, it needs to be replaced. But since it is supposed to work (both Infiniti web site and Verizon validate this).
Question: is there an update for the bluetooth software? Or should I just get a new phone and stop being cheap?
Thanks
Old Apr 16, 2009 | 08:03 AM
nr2d's Avatar
I have had this problem. It has been a momentary loss of blue tooth. I just attributed it to another vehicle with blue tooth passing by. It doesn't happen that often though.
Old Apr 16, 2009 | 10:19 AM
g35stylez84's Avatar
yeah happens to me all the time... mine just won't connect when i strart my car sometimes. its annoying as shyt... as far as being on a call outside of the car. u have to hit ok to transfer to bluetooth on you phone possibly. i have an LGVX1000 and it just doesn't like my car i guess
Old Apr 16, 2009 | 08:54 PM
neilmills's Avatar
I've had lots of problems with my phone too. It turns out there is a problem with Windows Mobile 6 phones and Nissan/Infiniti cars made during a certain year range. Calls have lots of static. I can hear the other party, but they can't seem to hear me. I've heard if you send the call to your phone, and then send it back to the car it will work again, but only for that specific call. My previous phone with Windows Mobile 5 worked flawlessly with my car.
Neither Microsoft nor Nissan seem to own up to the problem though, so no one seems to be looking for a fix. So my $40,000 car can't communicate with my $600 phone.
Old Apr 16, 2009 | 09:52 PM
coolguy8157's Avatar
I have MotoQ9c and the same issues and some wierd stuff happening like the car and the phone get connected and no voice commands work until I select the phone and select hangup on the display. This is a mess. I have the Nav. This is not happening with the 07 loaners that doesn't have the Nav. I had this issue with WM5 and now WM6.1. Same story. I'm just waiting for the HTC Touch Pro to be tested out by Infiniti.
Old Apr 17, 2009 | 10:03 PM
airhoppz's Avatar
Turn the bluetooh off on your phone, then turn it back on.
Some phones don't play well with the car's bluetooth. I can assure you it's not the car's fault, though. Infiniti already replaced my bluetooth module for free once and the problem still persisted.
Old May 18, 2009 | 10:37 PM
ABQ_G35's Avatar
I just got a new phone, and am experiencing a similar issue with the Bluetooth. Worked great with my old phone. It's paired to the car, and it finds it as soon as I start the car, but keeps disconnecting and reconnecting. It works just fine with my headset, so I know it's not the phone. What I also find odd is the screen shows no bars, even though the phone shows a strong signal. The phone is a Samsung Rant.
Old May 19, 2009 | 12:17 AM
PeterUbers's Avatar
I hope you all are updating the firmware on your phones....
this helped my wife's BT issues with her LG Rumor and her '08 G....
Old May 19, 2009 | 10:31 AM
jimmyjones's Avatar
I have an iPhone and can't get it to even connect to my car. Any hints? I tried searching for iPhone tips in the Search function but only came up with echoing and other issues...Thanks in advance!
Old May 21, 2009 | 06:45 PM
ABQ_G35's Avatar
Well, from what I'm finding, the phone isn't quite compatible with the Bluetooth in the G, that seems rather pitiful that it is compatible with my $69 Bluetooth headset and not with the G Bluetooth. What they describe the problem as is the "connection is not stable". Okay, but why if it's stable with my headset, why not with the G? To me that makes no sense!
Old May 22, 2009 | 12:07 PM
seeker92677's Avatar
It's not WM6, its actually the bluetooth drivers and chip in the phone that causes the issues of static. I have an HTC WM6 phone and there has been some minor successes with older bluetooth drivers, but nothing wide spread.
If that is your problem, when you place a call or receive a call, imediately after connecting, hit "use handset" then hit "phone" button again to make the call go through the car. This will usually clear up the static issue.
As far as the phone dropping and coming back, I have noticed similar issues when either on a call when I start the car or if car is running and then I go out with phone and it tries to pair with the car. The only thing I have found to fix this issue is getting off call and turning off car, then reset car and let phone pair w/ car.
Again, these are only temp fixes, the only real fix is to get a phone that is on the approved list on Infiniti web site.
Old May 22, 2009 | 12:58 PM
fecurtis's Avatar
My roommate has this problem with his iPhone in his M45x, I've never had a problem with either of my two phones I've owned since buying my G35 (both are Blackberries).
Thebaws11
Jul 2, 2021 11:36 AM
Marlin84
Apr 1, 2020 12:52 PM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
JustinMKN1
Sep 18, 2015 03:40 PM
