Auto Interior Illumination Stopped Working
Hi guys,
I had my g37 sedan tinted yesterday and I just realized it today that my car interior doesn't illuminate anymore when I unlock the door or stop the engine.
I checked the setting and turned it off/on but it didn't fix it.
The guy said he removed the door seals to prevent feeling but that's about it.
I'm not sure if it's coincidence or there's something else that I did.
thanks
thanks
What does "he removed the door seals to prevent feeling" mean?
Anyway, did the little push pin that tells the car when the door is open or closed get stuck? That's what controls illumination. OR, if you're talking about the main "dome" lights, think there's a switch to set those to On - Door - Off. Is it switched off?
Thanks for the reply guys.
Rear personal light, Map light and step lamp are always on / off depending of the interior light switch settings (on/off/door) and they always work.
I'm talking about the buttons / gauge / instrument lights.
You know when headlight is set to auto and you're exiting the car at night,
steering wheel buttons, all buttons on the panel are lit up.
I remember when I entered the car, soon after I pressed the button on the door, they are lit up as well.
Am I right? or was it a different car (I can't remember)? I only picked up the car few days ago so
Instrument Brightness is already set to MAX btw.
With mine the gauges are on day or night they just vary depending on that.
No, instrument panel does not light up when you just enter the car. It comes on when you switch to On (or possibly Aux - LCD comes on, don't think gauges come on).
The interior lights should come on (Map/Dome) and your Ignition button should light up.
Your dash cluster only comes on once the car is started, or the ignition switch is pushed to turn the ignition on to Aux/On.... just like Steve mentioned above
I thought mine was broken for months
Really... who ever heard of a half-lit button?
Micale757
Lighting
Apr 8, 2020 10:46 AM
