I need your oppinion
Old Sep 14, 2009 | 06:48 PM
pattyballs's Avatar
so, i am trying to decide.... i am on a tight budget right now and can only do one of the following two things. i am debating if i should get new tires since mine a pretty worn. i am think of going with a shorter sidewall. thinking of 225/50/17 tires. on the other hand i also want to get my rims powder coated glossy black.. not sure what to do!!! please help!! hahah
Old Sep 14, 2009 | 07:14 PM
nghiars's Avatar
TIRES!!!!!!! thats the only thing between you and the road! i would sitck with 225/55. 225/50 is going to be too small and create an uglier/bigger wheel gap.
Old Sep 14, 2009 | 07:16 PM
AesonVirus's Avatar
+1... larger wheel gap FTL. Plus, keeping the same wheels with a different tire causes the speedo to become inaccurate.
Stick with the same tires, or go to a bigger wheel.
Old Sep 14, 2009 | 07:36 PM
kregg's Avatar
Tires!
Tires first, especially since yours are worn. Unless you plan on letting your tires blow out and ruin your freshly powder coated wheels.
You can improve handling significantly if you go for stickier rubber. You wont really gain much with the 5% reduction in sidewall so stick with the 55's. I'd bet the variation from brand to brand & model to model in sidewall strength will impact handling more than going with the lower profile tire.
Old Sep 14, 2009 | 09:12 PM
Greekboy115's Avatar
This shouldn't even be a question. Tires should be first and formost in that situation! I was also stick to 225/55, the wheels can wait until later.
Old Sep 14, 2009 | 09:30 PM
firozu's Avatar
i agree with everyone trust me when you throw some new rubbers on ull get a ride thatll make you fall in love with the g all over again
Old Sep 14, 2009 | 09:51 PM
TLTONEY's Avatar
If you have plenty of insurance, paint the rims. Really, get tires if they are worn. Like he said above, new tires give you a new ride.
Old Sep 15, 2009 | 12:17 AM
DJ Hellfire's Avatar
If you wanna go to a 50 sidewall, then you should go with a wider tire, like a 245/50. Remember, the profile is a percentage of the tires width. So with a 225/55, 55% of 225 is 123.75mm. So if you wanna go 50 series you need 245/50; 50% of 245 is 122.5mm. This will keep your wheel gap in check!
Old Sep 15, 2009 | 11:54 AM
pattyballs's Avatar
Will a 245/50 fit on my stock rims?
Old Sep 15, 2009 | 12:35 PM
Yeah. But it'll may look a little beefy compared to the rim. It'll fit though!
Old Sep 15, 2009 | 12:40 PM
pattyballs's Avatar
Do you think it will stick out noticeably further out than the rim?
Old Sep 15, 2009 | 12:42 PM
pattyballs's Avatar
I would love to do it just worried its gonna look stupid lol
Old Sep 15, 2009 | 12:57 PM
Most likely yeah!
Old Sep 15, 2009 | 01:44 PM
tg1234's Avatar
Safety first!
Old Sep 15, 2009 | 06:02 PM
baileyt35's Avatar
So you don't kill someone or yourself get the tires, are we serious?
