rim problem
Old Sep 23, 2009 | 04:11 PM
pattyballs's Avatar
rim problem
not really sure how it happened but my rims have some nasty water spots on them. i tried everything to fix it but nothing is working. has this happened to anyone else? anyone know how to fix it?
Old Sep 23, 2009 | 05:45 PM
nghiars's Avatar
What type of rim do you have.. OEM, aftermarket, is it painted/powder coated.
Old Sep 23, 2009 | 06:37 PM
pattyballs's Avatar
stock rims
Old Sep 23, 2009 | 06:48 PM
nghiars's Avatar
have you tried to clay bar it? try asking your Question in the detailing sub forum.. those guys are experts on it. i have limited knowldge on this stuff.
Old Sep 23, 2009 | 06:50 PM
pattyballs's Avatar
not yet, im thinking about picking up mothers metal polish and clay bar and see what happens...good idea? lol before i waste like $20-$30
Old Sep 23, 2009 | 06:59 PM
anndy811's Avatar
try polish, that should get rid of the water spots. a small can of mothers polish is like 5 bux.
Old Sep 23, 2009 | 11:09 PM
terrycs's Avatar
The wheels normally do not water spot very easily with the factory clear coat. Did you wash the car/wheels yourself or did someone else do it? What was used to wash them?
Old Sep 23, 2009 | 11:17 PM
GLuXuRy's Avatar
first dont use metal polish on a finish that is not even metal .. your wheels are made out of metal, but they have a paint and clear coat on them
second try distilled white vinegar diluted with a 50/50 mix of distilled water (grocery store will have them both), if it doest work, up the mix with a stronger solution of distilled white vinegar
if that does not work, try a medium grade clay bar
if that does not work try a abbrassive compound
if that does not work, get them refinished, you let the spots sit on there for too long and it etched into the clear of the wheels
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
hurleyguys
18 Inch
Sep 9, 2015 12:24 AM
CrazyLogic219
Jul 23, 2015 10:58 AM
EasySausage
Jul 14, 2015 11:17 PM
