Parking Light Bulb Problem - Short?
Old Nov 26, 2009 | 08:45 PM
voltagefx's Avatar
Recently I noticed that one of my parking/clearance lights wasn’t working so I planned to replace the bulb thinking that it was burned out. After a few days of driving only during the day I made another trip at night and noticed that the same parking light that previously wasn’t working is now working again. Anyone else experience this problem or know what might be the cause? Hopefully not a short… The car is a completely stock 07 sedan with the stock bulbs.
Old Dec 3, 2009 | 12:28 AM
Rottten Appples's Avatar
Ive noticed this too but i believe I might've swithced a setting that turned off the blinkers upon locking/unlocking the car...? is this the same?
Old Dec 5, 2009 | 11:31 PM
voltagefx's Avatar
When I lock/unlock my turn signal bulbs flash; however, I'm referring to the parking/clearance bulbs which are located on the top corners of the headlight housing.
I don't think it was a setting because I noticed it while the car was running parked with the headlights on (I stepped out of the car to grab something). The driver's side was working, but the pass was not. Since that night, they've both been working so I'm not sure what is going on. I guess I could change the bulbs, but it seems that if was simply the bulb it wouldn't have came back on because it would have been blown...?
Old Dec 6, 2009 | 08:24 PM
voltagefx's Avatar
Wonderful, it was not working again tonight, then after about 20mins of driving it magically came back on. Guess it's time to replace the bulb to see if that helps. Maybe it's just me, but it seems crazy for a car costing this much to have a problem like this.
Old Dec 6, 2009 | 09:56 PM
tg1234's Avatar
Most likely a lose conection. Did you ever own a VW? Talking about problems with lights. Not many people reported this kind of issue with the V36. Sometimes it happenes.
Old Dec 7, 2009 | 11:23 AM
voltagefx's Avatar
I haven't had a VW, for the most part only Nissan/Infiniti's; first time I've had a problem like this though. So you think maybe the bulb isn't seated properly into the socket?
Old Dec 8, 2009 | 03:32 AM
tg1234's Avatar
Got to be something small. Probably just not seated in perfectly as you said. I would try to look at that first. It is really not common to have this with the Infiniti.
Old Dec 8, 2009 | 03:46 AM
gizmo134's Avatar
could be the bulb is shot, but if you hit a bump and the filament bounces and makes contact, it like spot welds itself and works. for alil while...
id say change the bulb and see what happens.
then you should change that whole "completely stock" thing.
Old Dec 9, 2009 | 03:06 PM
voltagefx's Avatar
Changed the old bulb out to a brand new OEM bulb. The old one didn't look blown; filament appeared fine. However, the bulb's glass was dark/burned in a circle around the filament which I figured was from age (60k mi and almost 3 yrs), but hopefully the new bulb will take care of the problem. I'll report back if it doesn't.
I know, I thought about using LED bulbs this time, but I've been keeping it stock to avoid issues like this.
Old Apr 23, 2010 | 07:08 PM
DJ Ernie's Avatar
I just noticed this problem on my car too. When i first noticed my orange parking light was off... i thought it was burnt out. So then i walked over to the side of the car and tapped the top of the light housing with my fist, and the light flickered back on!!
My car is a 2007 G35 sedan... everything is stock except for the exhaust.
Anyone know what the problem might be?? I'm gonna try and take it apart and see if something is lose.
Old Apr 24, 2010 | 01:13 AM
kool_yaar's Avatar
Most probably the bulb is just come loose of its socket, just push it back in i guess or it could be that the bulb is about to go out and when you tap it, it makes the filament move and make it work temporarily.
It is not a known/given issue from what i have seen on this forums
Old Apr 27, 2010 | 11:08 PM
voltagefx's Avatar
I haven't experienced any problem with mine since I changed out the old OEM bulb for a new OEM bulb.
Old Apr 27, 2010 | 11:16 PM
NBYOND's Avatar
Ya, most likely just a bad/worn out bulb.
Old Apr 28, 2010 | 08:50 AM
soundmike's Avatar
What's the best way to reach behind and replace that bulb without removing the headlamp assembly?
Old Apr 28, 2010 | 10:39 AM
voltagefx's Avatar
I used this thread as a guide when I replaced my bad bulb: https://g35driver.com/forums/v36-diy...n-install.html
Just to note this, my car had just over 60,000 miles when I replaced the bulb. I also had a license plate bulb fail that I replaced at the same time.
