roof spoiler not staying on
Old Mar 10, 2010 | 11:10 PM
pattyballs's Avatar
So today i was trying to mount my roof spoiler and the double sided tape they had on it is ****.. it wont stick at all....can anyone give advice on what to use to make sure it is really stuck down? I tried using a window sealant also but that didnt help at all... Thanks in advance for any and all advice
Old Mar 11, 2010 | 06:38 AM
AesonVirus's Avatar
First, the surface you are adhering to must be clean. Wipe the area down with rubbing alcohol to prep it for the double sided tape.
Some roof spoilers have fitment issues. If it's not perfect, it's basically trying to pull itself off as you're trying to install it. Whether it's tape or silicon as an adhesive, you may need to tape it down in place until the adhesive has had time to set.
Just curious... What spoiler are you installing?
Old Mar 11, 2010 | 09:53 AM
DrGeeMD's Avatar
I am guess it's a Ravspec as a lot of people, myself included, have issues to adherence, particularly at the two ends. I bought extra double sided tape and taped the spoiler to death. The ends still pop up a bit, but not noticeably. I didn't have to use sealant. I would give that a try. Oh, and as Aeson said, clean surface a must.
Old Mar 11, 2010 | 12:19 PM
kool_yaar's Avatar
the key for me was to help the adhesion by laying many layers of blue painters tape on the side for proper grip. Worked like a charm, 1.5yrs in and no adhesion issues, btw i did use windshield silicone adhesive.
Old Mar 11, 2010 | 12:44 PM
Sayuri637's Avatar
3M exterior double side tape with properly cleaned mounting surface as mentioned above and make sure to apply the tape to the entire footprint of the roof spoiler. My bf has 2 CF lip spoilers on his supra that are installed in this same fashion and they have been on the car for well over 2 years now with no issues.
Old Mar 11, 2010 | 12:55 PM
AesonVirus's Avatar
Exactly... that was where I was going with my question
Old Mar 11, 2010 | 11:32 PM
pattyballs's Avatar
I actually went with the Stillen... picked up the 3M tape since the original tape got destroyed....now im just waiting till my friend brings over his heat gun... thanks all for your advice i really appreciate it! will post pics when it is installed...hopefully sometime this weekend
Old Mar 12, 2010 | 12:48 AM
kool_yaar's Avatar
^ that could be the problem, there are various adhesion strength 3M tapes, the original one from Stillen is the Heavy-duty 3M which i believe is the strongest double sided foam tape they make. Check to make sure that the 3M you got it also a high grade high adhesion one... Plus the heat gun should be a big plus.
KruZZe
Feb 27, 2023 05:04 PM
g.spot
May 9, 2016 10:54 PM
dseet
Oct 11, 2015 12:40 AM
vamarris
Sep 26, 2015 12:56 PM
