I'm Changing Front Pulley Belt! any tips? (edited title)
Old Apr 20, 2010 | 09:39 AM
Shurik355's Avatar
*updated*
hi guys, I need to change my drive belt on my G35s. I got the belt and ready to put that thing in.
Did anyone change driving belt on their Gs???? How did it go? any problems? any tips on what I should do???
thanks guys
Old Apr 20, 2010 | 10:03 AM
AesonVirus's Avatar
Hmm... I thought we had chains and didn't require a change.
Old Apr 20, 2010 | 10:09 AM
G35Now!'s Avatar
Moderation-free
+1 Who told you we have a timing belt to change...?
Old Apr 20, 2010 | 10:34 AM
baksdak's Avatar
We have chains. In VERY rare circumstances they break. You should not have to replace this.
You are correct if your car had a belt. You would most likely replace the water pump and tensioner. Most cars this is a pretty labor intensive process due to the location for the beginner mechanic thus you might as well do all. Plus, the life on all can be about the same.
Old Apr 20, 2010 | 10:35 AM
kool_yaar's Avatar
^ like they said, we have timing chains that are maintenance free upto 100k, was the chain somehow damaged or broken during the wreck?
jwrape's Avatar
Don't change the chain. There is no need. It will go forever.... Don't bother.
Old Apr 20, 2010 | 10:42 AM
Shurik355's Avatar
ok guys, sorry for the misunderstanding. I didn't even know what we had a belt or a chain.
Well I was talking about the front pulley drive belt. The one I got is pretty bad after collision. So bought another belt to replace.
Sorry for confusion.
any info on those pulley drive belts??? shoud be easy to change, right?
Old Apr 20, 2010 | 11:26 AM
tonke73's Avatar
Easy is a relative term. I believe you have 1 belt.
1. drive onto ramps (not jack stands)
2. remove plastic cover
3. Loosen belt tensioner and/or alternator tensioner
4. remove serpentine belt (belt should have enough circumference to clear the fan)
5. replace serpentine belt
6. reverse steps 3, 2 and 1.
Old Apr 20, 2010 | 09:56 PM
kool_yaar's Avatar
^ Nice and accurate sum up, its an easy job for anyone who likes doing some DIY
Old Apr 20, 2010 | 11:48 PM
Shurik355's Avatar
ok cool got the drive belt put in. thanks for the input guys
....Next is engine mounts.
tiguy99
Mar 1, 2016 11:42 AM
MR M37s
Oct 30, 2015 08:32 AM
Th611
Oct 27, 2015 03:48 PM
kinetek
Aug 3, 2015 04:25 PM
newbdriver01
Jul 15, 2015 06:10 PM
