Regular Oil?
Old May 21, 2010 | 11:31 AM
LakeShore_Slate's Avatar
Fully synthetic here from when I first bought mine. I have ran it up until about 7k miles and done an oil analysis and could've safely ran a few more hundred miles until it would really need an oil change.
Old May 21, 2010 | 11:37 AM
tragedycat's Avatar
What about time interval? I've had Royal Purple synthetic sitting in my engine for about 5.5 months now but have only driven the car ~2k miles. Should I bother to change it after 6 months?
Old May 21, 2010 | 11:49 AM
Jeff92se's Avatar
Red Card Crew
You can get it analyzed and see how it's fairing. So the next time, you'll know how your oil will be at 5.5 months ~2k miles.
Old May 21, 2010 | 11:59 AM
soundmike's Avatar
Originally Posted by PocketMnky
I think that the only problem with using a synthetic oil is that people mistakenly believe that this gives them the ability to go 10-15k miles between oil changes which is absurd.
On the other side of the fence here, to be fair i've done UOA's for years now and have managed to go as high as 15k with no issue. Although i only did that once, mainly for my own peace of mind, even if the analysis showed things were fine.
Old May 25, 2010 | 07:18 PM
geronimomoe's Avatar
Originally Posted by 07CA6MT
Went to my local dealership to get the oil changed and they told be that they no longer put synthetic oil in because it burns and leaves residue in our engines. Anyone else hear about this?
Your local dealership has a bunch of thieves or idiots who shouldn't be in the car service business. Take a pick.
Old May 25, 2010 | 07:19 PM
Originally Posted by soundmike
Do an oil analysis. That's the best way to determine how long you should be keeping the oil in there.
+1. Oil analysis is the way to go.
Old May 25, 2010 | 07:23 PM
Originally Posted by jibberjabbers
Since synthetic is thinner than conventional, it does burn in our motor. Not sure about the residue part.
Synthetic is not thinner than conventional. A 5w-30 is a 5w-30. The viscosity of the oil (at cold and operating temperature) will fit into the same range, synthetic or dino.
Old May 25, 2010 | 07:25 PM
As Jeff92se said, get it analyzed to see how the oil is doing. However if you're still under warranty, change it after 6 months to keep the warranty. Once you're out of warranty you can do whatever you feel like doing!
f22raptor
Mar 18, 2016 08:50 AM
mbe32
Nov 13, 2015 11:09 PM
Learned Hand
Oct 1, 2015 09:02 AM
9tray turbo
Sep 29, 2015 10:22 PM
