Oil Change
Old May 29, 2010 | 07:57 PM
baksdak's Avatar
Oil Change
Just finished up my DIY oil change...first time on my G35. Have always done this myself on previous cars. Was a little more difficult due to the low ground clearance and thus had to use jack stands. Oh well. Once I removed the four bolts to fold the rubber flap and access the filter and drain plug it was cake.
The VQ is now lovin the Penzoil Platinum 5W-30 (Now on sale at Walmart: $20 for a 5 quart jug). I believe the previous owner had the dealer do it with the regular non-synthetic junk. I plan to do it again in 7,000 miles.
I would assume most of you do your own oil changes as well?
Old May 29, 2010 | 08:05 PM
kool_yaar's Avatar
ya its not that bad, i still change my oil around 3.8-4k with M1 full synthetic @ $32 for 5 qts and filter on special!! I always stock up when they have this special at advanceautoparts
Old May 29, 2010 | 08:14 PM
baksdak's Avatar
Nope, not bad at all. I was going to go with Mobil 1, but after researching some analysis results on bobistheoilguy.com, I chose to go the Pennzoil route. Results seem to be very good when put in the VQ. I did go with the Mobil 1 oil filter though!
You should definitely buy it at Walmart. I think I saw the 5-quart jug of Mobil 1 5w-30 for $23. I used to buy mine at Advance Auto Parts, but they are way overpriced.
Old May 29, 2010 | 08:29 PM
gary c's Avatar
Penzoil....they've been around for a hundered years but I think there's better sysnthetic oil available for our cars. Checking the oil content charts it appears that AMSOIL ATM 10W/30 would be the very best synthetic for my coupe, and SLICK deserves the best! I'm not concerned about cost and would rather not shop at a store like Wallyworld, I wish company's like Costco carried more automotive products....my .02 cents!
Gary
Old May 29, 2010 | 10:40 PM
jane's Avatar
Just did mine also with Penzoil Platinum 5W-30 but I had 15-20 screws to remove the plastic cover. Did my air filters also.
Old May 29, 2010 | 10:51 PM
Geemy's Avatar
just did my oil change also, 5 qrts of m1 full syn at meijers for $21
Do you guys change the washer on the drain plug every oil change?
Old May 29, 2010 | 10:54 PM
youngG's Avatar
i change the washer there cheap buy them from ebay
Old May 29, 2010 | 11:32 PM
thescreensavers's Avatar
Mr.202?
Penz Plat 5W-30 is great oil as well, Thought I would not run it for 7k with out first getting a UOA.
Old May 30, 2010 | 12:46 AM
jane's Avatar
Been changing my own oil since I was 17 and I've never replaced one.
Old May 31, 2010 | 06:58 PM
baksdak's Avatar
If you only take out the four screws that are at the back of the rubber/plastic undertray it will fold down so you can gain access to the filter and drain plug. If you look at the undertray, you will notice a crease or fold line that makes this possible. This is only on the RWD, the X is different.
Old May 31, 2010 | 06:59 PM
baksdak's Avatar
I have never replaced the washers on my old vehicles and chose not to do so this time either...
Old May 31, 2010 | 09:46 PM
jane's Avatar
Didn't notice. I took the whole thing off and didn't see anything like that. Interesting.
zoop425
Mar 29, 2016 05:51 PM
JoeMac
Aug 20, 2015 10:17 AM
linedr89
Aug 17, 2015 05:11 PM
ClwMike
Jul 23, 2015 12:55 PM
