Rear Seat Loose
Old Jun 3, 2010 | 01:30 PM
Snowman718's Avatar
Rear Seat Loose
hey guys im having this problem on my 2008 G35X. The bottom part of my rear seat on the right side is loose enough where i can put my hand underneath it by pulling it up. It feels as if its not bolted on is this normal? the other side does not feel this loose plzzz help if you can thank you
Old Jun 3, 2010 | 01:47 PM
mj_39's Avatar
the rear bench clips into the body of the car,look for a tab sticking out of the front of the seat, line it up with slot on the body of the car push down and it should click back in.
Old Jun 3, 2010 | 01:54 PM
Snowman718's Avatar
Thanks alot MJ im gonna go try this right now
Old Jun 3, 2010 | 02:06 PM
mj_39's Avatar
no problem let me know if this solves your problem!
Old Jun 3, 2010 | 03:03 PM
Snowman718's Avatar
I see a black circular tab you can pull but in that area it is tight mine is loose in the corner where the little dots on the leather end on the side part do you know how to tighten it up to the body of the car?
Old Jun 3, 2010 | 03:10 PM
mj_39's Avatar
so the clip which is on the bottom of the leather seat is clipped into the car properly?, you will hear it clip in. but its still loose?
Hotdawwgman's Avatar
good news is that its under warranty. Take it in bro... Dealers will not say no!
Old Jun 4, 2010 | 12:19 PM
Snowman718's Avatar
yea its on real tight...And Thanks guys for your responses i really appreciate it.
Old Jun 4, 2010 | 12:48 PM
kool_yaar's Avatar
its a bit confusing to understand the issue now since its seems to be clipped in properly, take pic and maybe someone can help you out more.
Or you could just unclip the rear bottom seat cushion from both ends and take it out and make sure nothing is stuck under the seat and try to reclip it properly, should take maybe 2-3mins max.
derres
Aug 28, 2015 03:27 PM
si_driver
Aug 11, 2015 07:08 AM
wuppiedog
Aug 7, 2015 11:16 AM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
atk08
Jul 30, 2015 03:12 PM
