Engine Vibration
Old Jun 11, 2010 | 10:36 AM
pianofrk4's Avatar
Engine Vibration
Guys,
I am so disappointed in my car right now...it's not even fun anymore
You guys have probably noticed I posted a few threads about problems on my car... mainly vibration issues..
So now, I'm experiencing more vibration issues...
recently, i've heard chirping sounds on my car... when it is REALLY cold out, i would hear it. Now, the weather is somewhat warmer (65 - 70 Farenheit).. and the chirp is gone.
Now, I'm having a problem with slight vibrations at idle!! it is very slight, but you can FEEL it in the steering wheel and the shift ****! also slightly on the floor board and my seat.
When I accelerate, you can literally feel the high frequency vibrations traveling up to the pedal, then to the steering wheel, then to the floor, then to the shift ****...almost simultaneously...
It is very small vibrations but enough to get my hands numb after 5 mins of driving!
Anyone have any suggestions as to what is happening?
Harmonic Balancer? driveshaft? ....uuugh... i'm almost starting to hate this car (2007 g35x sedan)
any input, much appreciated.
Old Jun 11, 2010 | 01:49 PM
Q8y_drifter's Avatar
first off, is the car stock?
Have you check the engine mounts? If you're having vibration issues standing still I would usually rule out any transmission/differential/transfer case mounts but I'd still have them checked just in case.
Old Jun 11, 2010 | 01:59 PM
pianofrk4's Avatar
Engine-wise, 100% stock. I only recently changed all 4 tires, and brake rotors/pads (to aftermarket). Otherwise everything is stock.
I could feel the engine in the steering wheel and shift **** and floor boards when I start the car and at idle... then when I hit the gas and accelerate, the vibration gets faster and can be felt traveling up from the floor into the steering wheel and shift **** and also into my seat... I've asked passengers if they feel a "humming vibration" sensation and they said no.. I think the driver is the only one that feels it cuz it's mainly travels through the steering wheel.
Where are the engine mounts on this car (07' G35x sedan)? How can I tell if it's worn?
Old Jun 11, 2010 | 02:20 PM
they are down low. You should be able to see them if you take off your intakes. Take it to a shop and let them inspect the mounts for any cracks, deformation, etc.
Old Jun 11, 2010 | 02:45 PM
pianofrk4's Avatar
gonna take it to the dealership next wednesday :/ Are engine mounts covered by original warranty?
Old Jun 11, 2010 | 02:52 PM
if you're still under warranty and they're worn out then yes.
Old Jun 11, 2010 | 03:27 PM
pianofrk4's Avatar
Sounds good. Thanks for the replies Q8y_drifter!
Old Apr 5, 2016 | 12:42 AM
g352k7's Avatar
Hi, were you able to get this sorted out? I'm having similar issues with my 2007 g35.
Thanks!
Old Apr 5, 2016 | 10:49 AM
07-G35-MT/S's Avatar
Six years later, they all rattle!!!
Freeman186
Sep 6, 2023 10:07 AM
alessandro
Oct 8, 2015 09:29 AM
Joe Gargano
Sep 18, 2015 11:17 AM
AT23
Sep 15, 2015 07:44 PM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
