Oil Change?
Old Jun 17, 2010 | 08:37 PM
jane's Avatar
Originally Posted by SCOOBY617
ouo dont have to take off the whoe heat shield to get to the filet, there is an opening.. 2 screws and gives u full access to drain plug and filter.. f*** taken the whole shield off..
Myy 08 does not. You have to drop the whole shield.
Old Jun 17, 2010 | 10:40 PM
blnewt's Avatar
My 07 and now my 09 both had the "hinged" plastic cover. If you remove the back 4 bolts the plastic cover folds down at the "hinge" and gives you access to the plug & filter. Your 08 should be the same (not sure about the X models) but Base,Journey & Sport are that way.
Old Jun 17, 2010 | 11:43 PM
E-Ticket Ride's Avatar
My 08 has a rigid one piece cover.
Old Jun 18, 2010 | 09:53 AM
terrycs's Avatar
There are several configurations of lower engine covers. I think there is even one with a trap door. Although my lower shield is hinged, it will not allow access to the filter and drain.
I'd still prefer to remove the whole thing so I can just take a look around to see if everything is OK while I am under there and so I can dump out any road gravel that has accumulated on the shield.
Old Jun 18, 2010 | 10:42 AM
jane's Avatar
Nope! I didn't notice it when I changed my oil. Someone said it's thee. I went and checked again. Not on mine.
Old Jun 18, 2010 | 02:45 PM
blnewt's Avatar
That's so strange that they would make a different pan for the 08, maybe it depends on the region the car is sold? Oh well, glad mine have had it
zoop425
Mar 29, 2016 05:51 PM
JoeMac
Aug 20, 2015 10:17 AM
linedr89
Aug 17, 2015 05:11 PM
ClwMike
Jul 23, 2015 12:55 PM
