squealing windows
Old Jul 4, 2010 | 11:01 PM
G420's Avatar
squealing windows
the dealer says to put grease inside the rubber to prevent this but theat leaves an inch of greasy residue on my windows when its rolled up.
anybody have any easier way of doing this?
Old Jul 4, 2010 | 11:40 PM
JAYY-G35's Avatar
I'm guessing after a while the greasy res will go away. I have to do my doors as well
Old Jul 4, 2010 | 11:52 PM
AesonVirus's Avatar
Mine only squeal when they are wet and that is only since the tint was put on.
Some people replace the OEM rubber with a softer felt strip to avoid eventual marks on the tint. A softer felt would not squeal.
I would not, however, lubricate them with grease, as this will get all over your windows.
I'd rather listen to 5 seconds of squeal than have greasy windows, but that's just me.
Old Jul 5, 2010 | 07:02 AM
g35xdriver's Avatar
g35x
I use a thin coat of pure silicone grease in all the grooves, and around the doors, trunk, hood, etc (all the rubber gaskets). No residue on the windows, safe for the rubber, no squeaking. Only takes a very thin coat and it's great protection.
Old Jul 5, 2010 | 09:48 AM
JZeezG35's Avatar
what he said
Old Jul 5, 2010 | 02:53 PM
terrycs's Avatar
This may or may not be related.
Although my windows don't squeal, the tint on my drivers door window is beginning to show vertical scratches near the middle of the window. I recently noticed that the rubber on the "inner guide" was twisted and will require a trip to the dealer.
To see what I mean, open your window all the way down and slightly pull apart the window seal at the bottom near the middle of the opening. You should easily be able to see down inside the door and see the glass and guide. The "felt" lined rubber on the inside guide next to the glass was twisted and the smooth rubber side is now rubbing against the tint.
Maybe this could be a source of your squeal?
Old Jul 5, 2010 | 06:18 PM
dohturdima's Avatar
+1 on this. It also "cured" my slow rolldown/rollup. I used silicone spray instead.
Old Jul 6, 2010 | 11:14 PM
G420's Avatar
i just got some silicone spray they didnt have grease at lowes seems to be working thanks
Old Jul 7, 2010 | 02:45 AM
tg1234's Avatar
+1 on the silicone grease.
Dallsinghjr1
Sep 17, 2023 11:25 AM
Picture Share
Feb 4, 2018 12:41 PM
BradMD_96
Oct 6, 2015 09:31 AM
dcsbh1
Oct 1, 2015 03:15 PM
Learned Hand
Oct 1, 2015 09:02 AM
