Replacing Lamps
Old Aug 11, 2010 | 05:22 PM
rdeol's Avatar
Replacing Lamps
Hi Guys,
I'm a new G35s 2007 owner and looking to replace the lamps inside and out.
I have been to the Osram Sylvania website and have figured out what lamps I need to change but also looking to hear input. I would like to change the following:
Map light (DE3175) - to white LED type
Clearance light/Front side turn signal (2827) - to match the headlights what color temp should I get?
Front Turn signal (992) - to a white LED type? Suggestions?
Fog Light (9006) - also to match the headlight color?
Step Light (DE3022) - white LED type?
I used to own an Integra and once I changed out the turn signal bulb with a LED I had a rapid turn signal (Which I liked).
Question is will this throw any error codes on the computer for the G35 or is there a way around this?
Thanks
Old Aug 12, 2010 | 12:25 PM
djfarhan's Avatar
Old Aug 12, 2010 | 05:48 PM
samsizzle's Avatar
http://gshack.org/?p=3
11bEMT
May 27, 2022 03:13 PM
ara777
Aug 15, 2018 04:11 AM
snic09
Nov 8, 2017 01:46 PM
miata007
Aug 17, 2015 04:36 PM
Karl_g335x
Aug 3, 2015 03:43 PM
