Having some issues with my car can anyone diagnose what they mean?
Old Sep 29, 2010 | 10:20 AM
KBS756's Avatar
Hey, I'm having some wierd issues with my car and would appreciate it if anyone could diagnose what is causing them
I have a 2008 infiniti g35xs which i leased new and now has 29k miles on it.
The issues I'm having is every time i drive it after a couple mins of driving the VDC off light and slip light turn on and stay on and other then turning on and off the car they wont go away.
the other issue I have is that whenever i accelerate moderately hard right around 35 - 40 mph from stop if i havent gotten off the gas (highway merge)
the red brake light comes on and until i get completely off the gas for a couple seconds it doesnt go away (and the engine also seems to cut off)
if anyone could let me know what this is i would greatly appreciate it thanks
Old Sep 29, 2010 | 10:23 AM
apexi957's Avatar
Why don't you take it to the dealership?
Old Sep 29, 2010 | 11:04 AM
RemmyZero's Avatar
the brake light is likely just low fluid, nothing serious. when you accelerate the fluid backs away from the sensor, turning on the light. add a little bit and it should go away. take care not to add too much because when you change your brake pads the fluid level will rise up considerably and you don't want it to overflow.
the engine cutting off though, the rpms just dip down and come up? you might need to clean your throttle bodies, i was having the same issue until i did. but dont disregard that symptom, be sure to keep an eye on it.
regarding your VDC and slip light that sounds like a sensor issue but you definitely want to have the dealer take a look. maybe someone else can lend some information.
apexi - normally i would agree with you but in many of the cases i'm seeing (and mine) the dealer is an hour or more away and it's very inconvenient to go there. luckily we have alot of knowledegable people here!
Old Sep 29, 2010 | 11:11 AM
tg1234's Avatar
That means get ready for $$$$$ you'll need a brake job sooooooon.
Old Sep 29, 2010 | 11:22 AM
tpc303's Avatar
I'm having the same issue as of today
Old Sep 29, 2010 | 12:18 PM
KBS756's Avatar
Hey thanks for the advice guys, If i were to drive to a dealer what do you think whatever id have to get done would cost me?
Old Sep 29, 2010 | 12:19 PM
LakeShore_Slate's Avatar
I have experience similiar. The brake light coming on **but not staying on and the slip coming on which does stay on until I turn off and back on** The slip light doesn't come on and stay on in every situation that I break traction only certain times. Good luck to you my man.
Remmy is right about the fluid** and about people living 1hr+ from dealerships
Old Sep 29, 2010 | 12:52 PM
kool_yaar's Avatar
@KBS it should not cost you as long is its something thats still covered under warranty that i believe it should be.
Old Sep 29, 2010 | 12:55 PM
velomack's Avatar
Top off the brake fluid
Old Sep 29, 2010 | 12:56 PM
KBS756's Avatar
K THANKS guys, ill try to go to a dealer this weekend .. hopefully get this dealt with
Old Sep 29, 2010 | 02:56 PM
RemmyZero's Avatar
+1 this shouldn't cost you anything. also you can try calling your local nissan dealership and see if they will honor the warranty, maybe they can help if they are closer.
Old Sep 29, 2010 | 04:57 PM
lundy's Avatar
mine was the same. Top off the fluid. I actually was buying it from the dealership and this was happening on my test drive. The tech's at Infiniti had it for an hour or so before I googled it on my phone. Brought me straight to this site. First post I read talked about the fluid situation. I told the tech to top off and it was fixed. g35driver FTW on this one. Infiniti FTL
chinee
Jun 10, 2024 07:48 PM
rezendvous420
May 31, 2020 01:26 PM
newg37
Jul 26, 2015 09:32 AM
itschuckster
Jul 25, 2015 08:07 AM
ClwMike
Jul 23, 2015 12:55 PM
