HID bulb brand for sedan
Old Nov 7, 2010 | 07:52 AM
georgesa's Avatar
What's the brand and model for the HID bulb for the 07+ sedan? Is it Philips 85122, Philips 85122+, or Osram ???
I'd like to purchase as close as possible to the OEM one. Any recommendation where I can buy these too?
Thanks.
Old Nov 7, 2010 | 09:37 AM
mishmosh's Avatar
I'd try to find another g owner in your area with stock bulbs they have swapped out for cooler temp capsules.
Old Nov 7, 2010 | 10:15 AM
EnviedG35's Avatar
Neither. OEM bulbs are Koito bulbs, made in Japan. Your best bet is ebay.
Old Nov 7, 2010 | 12:51 PM
mathnerd88's Avatar
I think bmw uses the philips 85122 bulb as their oem....which is better imo...the stock bulbs I have are different intensities...the bmw bulbs seem brighter and illuminate better.
kool_yaar's Avatar
^ +1 all you need is 4300K if you want same color as stock, i believe our bulbs are D2S, if you want brighter go with 6k i think thats the perfect intensity and color.
Old Nov 7, 2010 | 12:53 PM
E-Ticket Ride's Avatar
FYI: an increase in K decreases the amount of light output.
Old Nov 7, 2010 | 02:12 PM
mathnerd88's Avatar
I want to try the Philips 85122+ (I believe it's 4100k)...They have virtually no color shifting while the Philips 85122 has color shifting as they get older....I usually would get these here...
http://www.theretrofitsource.com/pro...cf0009e1f88cf4
These are only made in Germany.
Philips are the most well known company for making HIDs. I think they pioneered the HID technology. You can't go wrong with them.
Old Nov 7, 2010 | 04:47 PM
mathnerd88's Avatar
I wonder if the Philips Bulb is capable of hi beam lights...Our cars use the same bulb for high beams, I believe...does the ballast switch from 35 watts to 55 watts? Please can someone confirm that the Philips bulbs are compatible with the high beams?
Old Nov 7, 2010 | 04:52 PM
No, there's a movable metal shield inside the HID projector that flips up/down when you flash the high beams.
I don't know if this is our exact projector, but the mechanics are similar:
Old Nov 7, 2010 | 05:00 PM
soundmike's Avatar
The "+" series has already technically been color-shifted from the factory (It's closer to 5000k in reality. Good 4100/4300k bulbs eventually cool down as it shifts). It was developed to help owners replace just one burnt out bulb while maintaining uniformity between both headlights.
Old Nov 7, 2010 | 05:32 PM
gtbigup01's Avatar
^ They actually developed it for that reason? Helping out the consumers, woooowww, but good. I hate seeing cars approaching with two different intensities headlights. I dont think some of them even know it's like that, they just replaced one bulb and rolled out.
Or maybe they're aimed differently which would mimic the look of different intnsity.
Old Nov 7, 2010 | 06:39 PM
mathnerd88's Avatar
Funny, because other forums say that the + series are 4100k while the non + series are 4300k...
My headlights are different intensities, but I am too lazy to replace them and they kind of cost a lot of money. My headlights still work fine and I still can see the road well...
Here is the comparison of the two:
http://www.8thcivic.com/forums/light...2-85122-a.html
Old Nov 7, 2010 | 07:16 PM
soundmike's Avatar
My mistake, it's been a while since i had those bulbs (on my Maxima). I double-checked my records and it was the CM-series that i had, which are closer to 5000k, not the + series.
Twinturbo09
Lighting
Aug 3, 2015 11:06 PM
keithk831
Steering & Suspension
Aug 2, 2015 09:50 PM
julian.dion
Lighting
Jul 29, 2015 12:47 AM
attarday
Jul 15, 2015 04:03 PM
