No Powered Rearview Mirror??? and Radar Detector
Old Dec 29, 2010 | 01:40 AM
ChinkyChoy's Avatar
So i am planning on buying a radar detector and hard wiring it, but the problem i have is i dont think i have a powered rearview mirror (i am away from my car)...
is there another way to do this or am i forced to use the cigarette lighter outlet?
-Thanks!
Old Dec 29, 2010 | 01:54 AM
lefizzet's Avatar
I'm pretty sure you can hardwire it to the fuse somewhere or the vanity light or something along those lines. Most people with the setup have the homelink mirror though which makes it a breeze as with the setup I'm running.
edit:so you'd just have to buy a longer invisicord
Old Dec 29, 2010 | 02:07 AM
ChinkyChoy's Avatar
dang yeah...
did the homelink mirror only come with the tech or prem package?
Old Dec 29, 2010 | 02:01 PM
kool_yaar's Avatar
^ premium
Old Dec 29, 2010 | 05:47 PM
zoop425's Avatar
Its really easy. Extend the power and ground, run it along the headliner, down to the driver side footwell. Then get power from the fuse box using an add a fuse and ground it to the bolt under the carpet rite there. 15 minute job at the most. PM me if you have any other questions.
Old Dec 30, 2010 | 12:33 AM
ChinkyChoy's Avatar
so basically get a really long invisicord and run it down to the fuse box.
i m just confused as to where i should add the fuse and i could get the fuse at?
thanks for the help!
Old Dec 31, 2010 | 06:03 PM
zoop425's Avatar
go to auto zone and get an "add a fuse" attach the power wire for the radar to it, put in a 3 amp fuse in the accessory spot, put it in the cigarette lighter fuse spot and put an equally matched fuse in the other spot on the add a fuse. (you will need ATM fuses to put in the add a fuse (3 and however many amps the existing fuse it) because the ones in your car are ATM low profile and don't fit in the add a fuse.
Old Jan 11, 2011 | 02:07 PM
RemmyZero's Avatar
do yourself a favor and go on ebay and get yourself a homelink mirror. i forget the name of the seller but if you search here you will find him, he sends a kit with the wires and harness for you. its easy to install. the self dimming function is worth it!
cheers!
Bob
Old Jan 11, 2011 | 05:47 PM
chapter29's Avatar
Adding a HomeLink mirror presents the very same problem doesn't it? Power. I doubt they wired for the mirror.
I asked about the mirror that some G owners have that has the built in compass. They said my car wasn't wired for it, though I should revisit that as the compass they provide is very annoying.
Old Jan 11, 2011 | 10:30 PM
H2S's Avatar
H2S
Carefull. I used an inviscord to my mirrors power and it blew a fuse that prevented the car from going out of park or turning off. Using lightercord right now, put plan to hardwire to fuse box soon. Had to tow it in. Dealer actually replicated issue I was there. Started after one year. Very Weird.
Old Jan 12, 2011 | 08:11 AM
RemmyZero's Avatar
its not really a problem, just remove the a-pillar cover and run the wires down to the fuse box. tap your ground, tap your hot using an add-a-fuse and you're done. voila!
i honestly can't remember if i posted a thread about adding the mirror but i'm sure someone on here has. it's quite easy.
Old Jan 12, 2011 | 07:37 PM
chapter29's Avatar
I have an Invisicord powering my radar detector from my mirror and it is GREAT. I have always hated using the lighter.
Old Jan 12, 2011 | 07:49 PM
CALex's Avatar
Just fuse the radar detector with a 5 amp fuse and pick up power and ground at the sunroof motor. It's easy and plenty safe.
Old Jan 12, 2011 | 10:32 PM
zoop425's Avatar
I am pretty sure you are jumping to conclusions. There is no way that drawing a small amount of current from the 12v line in the mirror would blow a fuse that did that. Its an ACC 12v line meaning it would not ever have anything to do with those issues.
suby01
Not G35 Related
May 25, 2016 03:07 PM
atomevolution
Engine - Exhaust
Oct 12, 2015 01:00 PM
the93owner
Sep 28, 2015 10:37 PM
vamarris
Sep 26, 2015 12:56 PM
