Trans problem, car in dealer, any suggestions?
Old Jan 3, 2011 | 08:46 AM
rwade's Avatar
I have a 2007 g35x 5/at 4dr 59k. While driving in manual mode as well as sport mode every gear except first has a skip between 3k-4k rpm. the higher the gear the lower the rpm it skips at. When I say skip it is just a split second where it almost feels like something engages that puts a load on the engine( almost like when you turn the a/c on in a 4cyl ) and the RPM's drop (about 100-150 rpm). I was thinking it was the torque converter but why in 2nd and 3rd gear? The dealer is saying it's the same on all of those models that they have on the lot. I can find some others with the same problem but no solutions or ideas. I just wanted to put this out there to see if anyone had a solution for this. Thanks in advance.
Old Jan 21, 2011 | 02:20 PM
heynow's Avatar
That almost sounds like it's slipping. Better get that extended warranty
Old Jan 21, 2011 | 02:35 PM
miltoda's Avatar
Sounds like the torque converter coming in and out of lock to me. There's a sensor on the torque converter that sensing the line pressure and/or temp (I can't remember which) that determines if the converter is able to lock-up. Maybe that sensor is going bad. Or maybe the trans is just a lemon. Either way you're under warranty.
Old Jan 21, 2011 | 02:42 PM
bluedevils95's Avatar
good thing your still under warranty. i also say get the extended warranty
Old Jan 21, 2011 | 07:54 PM
cbrseadude's Avatar
Forgive me if im wrong, because im new to the infiniti world, but this sounds like a torque managed shift to me, most modern cars do this. When a trans slips, theres a flare up in rpms, not a drop. And when a torque converter is going bad, they usually shudder on engagement. The dealer said what your experienceing is normal?
Old Jan 21, 2011 | 09:23 PM
Anton_Chigurh's Avatar
Sorry to hijack thread..but can you get the extended warranty with Infiniti any time? Got 8k left on my powertrain
Old Jan 21, 2011 | 09:59 PM
baileyt35's Avatar
I was told by my dealer it has to be by 70k...so at 63k I'm about to grab the extended warranty for $1149 for 24mo/24k with $100 deductible.
Courtney Mutema
Finance Manager
Infiniti of Scottsdale
cmutema@vtaig.com
480-941-0055
Old Jan 21, 2011 | 10:19 PM
Courtney Mutema
Finance Manager
cmutema@vtaig.com
480-941-0055
Extended is only power train correct? Hmmm i may get this. I still got 8k to decide and wont hit 70k until summer...hmm is it worth it?
Old Jan 21, 2011 | 10:39 PM
BionicG35's Avatar
My 07 g35s does the same thing. I read in a different thread that some members had same problem fixed by an ecu and tcu update as per a tsb. I will try to find that info and post here...
Old Jan 22, 2011 | 07:06 AM
Q8y_drifter's Avatar
can you get the problem on video if possible?
Old Jan 22, 2011 | 09:14 PM
BionicG35's Avatar
I found the tsb for ecu flash, I don't know how to link to the thread but the tsb number is 23710-jk69d. Also in the same thread was a tsb for throttle sensitivity itb08-017a. I am very far from a dealer but hope to visit one soon for these updates. Let me know if this info was helpful..
Old Jan 22, 2011 | 10:00 PM
RedBaronK's Avatar
This only happens in manual mode or in auto too?
chinee
Jun 10, 2024 07:48 PM
NemesisGee
Aug 11, 2015 07:10 PM
wojowojo16
Jul 27, 2015 09:57 AM
newg37
Jul 26, 2015 09:32 AM
Kal Hamm
Jul 24, 2015 08:55 AM
