Problems with the A/C
Old Feb 11, 2011 | 03:43 PM
NewGuyG35's Avatar
Sorry if this is not the correct if so please move.
Anyways, I noticed that the A/C doesn't blow air anymore. All buttons and functions work completely find however, the air doesn't blow. I can barely feel it if I press my hand on the vent. The other thing is that sometimes I'll be driving in the freeway and the a/c will start working again. So basically this ****er wants to work when it wants to.
Your thoughts?
Old Feb 11, 2011 | 05:42 PM
anrman's Avatar
I just want to move to wherever you are in need of an a/c right now.
Old Feb 11, 2011 | 06:06 PM
RhiNoKiLL's Avatar
Are you sure you have the air blowing through the top vents and not at the windshield or feet?
Old Feb 11, 2011 | 11:45 PM
NewGuyG35's Avatar
Still not that hot in my area but the other day I turned it on for the hell of it and noticed the probolem. No I made sure I checked that the vents fron the dash board were set to blow but nothing. I want to take it to the dealership but wanted to get some input from here before doing that.
Old Feb 12, 2011 | 09:20 AM
dakiddanthony's Avatar
Basically somethings wrong with your deck. Whether it's ashore or something. Mine actually has that problem. On my 03. But it's not just the AC. it's the deck in general. The radio won't power on either when that happens. Can't control anything except the gps. I have an 03 sedan. This is a normal problem for the G. my cd player is also stuck. Theyre replacing my deck today actually.
Old Feb 12, 2011 | 09:22 AM
A short*
Old Feb 12, 2011 | 11:09 PM
SiK SedaN's Avatar
It might just be your fan. check the fuses.
If you feel it start blowing on the freeway its probably just outside air coming through due to higher speeds
Old Feb 12, 2011 | 11:10 PM
SiK SedaN's Avatar
LOL. come to cali man! I just had to use my AC today it was almost 80
Old Feb 13, 2011 | 09:49 AM
preston8o8's Avatar
so warm in cali it was 80 yesterday in long beach
Old Feb 23, 2011 | 08:27 AM
3lpaisa's Avatar
lmao!!!! south florida 85 d weather lmao
Old Mar 12, 2012 | 02:37 PM
PG35_LA's Avatar
A/C problems
Your thoughts?
Hey I know this thread was opened last year, I am having the same problems with my 07 sedan. Did you take your car to the dealer, what was the issue?, how were they able to fix you A/C problem. I appreciate any help.
Old Mar 12, 2012 | 03:03 PM
rpm&my_G35's Avatar
Did you guys ever check and/or replace the cabin filter. If it's extremely dirty it would affect the air flow.
Old Mar 12, 2012 | 03:53 PM
PG35_LA's Avatar
I just changed the cabin filter six months ago, I will check again thanks
Old Mar 13, 2012 | 01:52 PM
PG35_LA's Avatar
I just checked my cabin filter its still pretty clean, any other advice?
Old Mar 14, 2012 | 04:44 PM
k.desilva91's Avatar
I was having a similar issue... took it to the dealer and they replaced the relay to the blower motor. Now the car's a/c and heat comes on right away.
this thread helped me out
https://g35driver.com/forums/general...mittent-2.html
