Drain my Tank
Old Mar 6, 2011 | 03:13 PM
nago35's Avatar
Drain my Tank
I need to drain my 07 35 tank. I used some pump from home depot, but taking forever. Is there a way I can activate the fuel pump so it will continuously pump? I need to drain due to bad gas. Thanks in advance for any help.
Old Mar 6, 2011 | 03:17 PM
WhosRich's Avatar
Siphon it out?
Old Mar 6, 2011 | 03:21 PM
nago35's Avatar
tried that....i was using a siphon pump....no luck...
Old Mar 6, 2011 | 04:11 PM
E-Ticket Ride's Avatar
Why you think you got bad gas?
Old Mar 6, 2011 | 04:22 PM
Austin713's Avatar
^^ maybe his car is having stomach cramps
Old Mar 6, 2011 | 05:30 PM
Neal376's Avatar
run the fuel lines to a bucket and turn the key to the on position.
Old Mar 6, 2011 | 05:36 PM
nago35's Avatar
i confirmed it when i saw the gas was orange with chunks...very nice image...
key on and lines in bucket would work? i thought about it, but thought it would only pump if car was on..hmmm...lemme try
thanks Neal
Old Mar 6, 2011 | 05:42 PM
Neal376's Avatar
thanks Neal
why are you doing this anyways? someone accidently put diesel in your tank?
Old Mar 6, 2011 | 06:24 PM
kool_yaar's Avatar
^ no he said he got some bad gas... "i saw the gas was orange with chunks..."
You should have been able to siphon out the gas easily not sure why that didnt work, this is a good idea and should work but is a bit more work imo.
Old Mar 6, 2011 | 06:25 PM
nago35's Avatar
i turned the key on but the pump stays on only about 10 sec or so...i then decided to try to jumper the red and blk wires going to the pump...worked wonders...didnt want to try either cuz i was not sure, but i went out on a limb and it worked.
i was empty, got gas, and then the gas i got was orange and full of chunks or they filled their tanks with diesel by mistake, so draining and cleaning, then adding new gas with heet.
Old Mar 6, 2011 | 06:28 PM
kool_yaar's Avatar
^ wow that sounds awful! you should go back to the place you got the gas from with a sample and try to get some small settlement out of this glad it worked out for you though.
Old Mar 6, 2011 | 06:43 PM
nago35's Avatar
ya i got a gallon of it ready for tm
Old Mar 6, 2011 | 07:35 PM
mikeb2's Avatar
This may or may not be your case but it's always advisable to *not* get gas while the delivery truck is filling the ground tanks. The rush of gas into the tanks can stir up any sediment at the bottom and you can bet that those tanks are never cleaned out. Even so, I would have thought that the filter system in the stations pump would have strained anything out.
Anyway, good luck....
Mike
Old Mar 6, 2011 | 11:44 PM
Neal376's Avatar
yea, i think thats the actual way to do it lol
good to hear.
Old Mar 6, 2011 | 11:51 PM
bluedevils95's Avatar
WOW! That sucks! Do you have pix of this image?
