Installed my Invidia exhaust (lots of pics and videos)
Old Mar 18, 2011 | 03:37 AM
  #46
26th street's Avatar
Sounds great, but it looks even better..
Old Mar 20, 2011 | 08:06 PM
  #47
theophilus's Avatar
sounds awesome! i recently installed a custom magnaflow setup...but hope to eventually check out the invidia. thanks for the updates!
Old Mar 20, 2011 | 11:08 PM
  #48
vince1's Avatar
Wow looks and sounds great. nice pics and videos
Old Mar 21, 2011 | 03:46 AM
  #49
mysoda's Avatar
hi, i notice when you were cruising around town the rpm is only between 1-2krpm. do you know what your avg. mpg??
Old Mar 21, 2011 | 09:19 PM
  #50
Kube929's Avatar
is this new Invidia called the Gemini or the Q300 updated? I want to make sure i'm asking the vendors for a quote on the correct model
Old Mar 21, 2011 | 09:27 PM
  #51
soundmike's Avatar
Hopefully this helps.
Unless your vendor is moving *very* old stock, all of them will have the new resonators and x-pipe regardless of what it's called. I don't think even Invidia has really officially changed names on these as they're still using them interchangeably.
Old Mar 22, 2011 | 04:50 PM
  #52
pbabajan's Avatar
on their site its only under the q300 name
Old Mar 22, 2011 | 05:49 PM
  #53
soundmike's Avatar
"Gemini" is the newer version, so you just confirmed that Invidia's website is still not updated.
Without repeating what's already been said, kindly follow this thread:
https://g35driver.com/forums/v36-eng...ia-gemini.html
Old Mar 24, 2011 | 09:24 PM
  #54
pbabajan's Avatar
hey apexi did u get the hfc before the exhaust? if not how much louder did it get after the hfc?
Old Mar 25, 2011 | 12:04 AM
  #55
apexi957's Avatar
I got the HFC way before the exhaust, but i installed it when the exhaust arrived. I can tell you that the HFC does make a difference as well. It makes it sound more "G" like and a bit deeper. Love it! I'm kind of tempted to pick up some resonated test pipes as well.
Old Mar 25, 2011 | 12:24 AM
  #56
pbabajan's Avatar
i LOVE the way ur car sounds if i could i would get the same set up! hfc are illegal in CA tho!
Old Mar 25, 2011 | 09:34 AM
  #57
Kube929's Avatar
I just ordered this exhaust + berk HFC. The first thing I'm doing is painting the cans. Im digging the OEM look
Old Apr 6, 2011 | 08:30 PM
  #58
Kube929's Avatar
I just put the Invidia exhaust on today. My first impressions are that I like it more than my previous ARK exhaust. It's a lot more subtle under normal driving and comes alive when you're WOT. I'm happy I made the change.
OP - What temp paint did you use on the mufflers, 500 or 2000? I wanted to install the exhaust first to make sure I liked the sound before I painted. Now that I know i'm keeping it i'm going to paint the muffler for a more OEM look.
Old Apr 6, 2011 | 08:32 PM
  #59
soundmike's Avatar
You should be fine with 500 degree paint. FWIW, here's something to help you decide for yourself
https://g35driver.com/forums/5714340-post41.html
Old Apr 6, 2011 | 08:35 PM
  #60
Kube929's Avatar
Wow this is perfect. I wasn't sure how hot the muffler would get. Thanks bro!
