VDC and slip light staying on....
Old Apr 6, 2011 | 05:07 PM
Fendi35's Avatar
I just picked up my car from the body shop got a bit scratched up so was fixing it. Maybe 2 miles from home my vdc light came on and slip was on.... they both stayed on...
Now the problem was when ever i was driving past 2k rpm my car would like jump like go stop go stop the rpms that is and my car....
Now i have the injen cai could they have gotten wet...
Any help is appreciated it thank you...
Old Apr 6, 2011 | 05:16 PM
johnnyzee's Avatar
Low brake fluid is the problem. Top it off and the lights will go away. I had the same problem and so did MANY others on here (search if you dont believe me). what happens is as the pads wear the fluid level drops and the dash lights light up. Dont overfill the fluid, just top it off and you're good to go.
Old Apr 6, 2011 | 06:36 PM
Fendi35's Avatar
Ok so i went and bought some brake fluid... on my way my car shuts off... turn it back on after a couple times of trying still keeps jumping at 2 k rpm... as im bout to pull into the store check engine light comes on... had the guy hook it up to there computer there a code with the mass air flow sensor and an o2 sensor....
Im thinking its something due to my intakes because it rained here a lot dint drive thru any puddles or anything....
Im thinking about calling the infiniti dealer and setting up an appoint for it but should i take the cai intakes out before i go...
please help
thank you
Old Apr 6, 2011 | 07:03 PM
kool_yaar's Avatar
which intake do you have? either way u should definitely take out the intakes if its the MAF sensor cause that can easily be linked to your intakes and they can deny repair under warranty. If you have SRI then you should be fine.
Old Apr 6, 2011 | 07:06 PM
Fendi35's Avatar
I have the cold air intakes the ones that come down into the fenders....
Old Apr 6, 2011 | 07:57 PM
Fendi35's Avatar
Yea just talked to a buddy of mine samed thing happened in his old car when he had cold air intakes.... i guess i did mange to get some water into them...
Old Apr 6, 2011 | 08:00 PM
G35thrilla's Avatar
i had this problem where the lights were coming off and it were my brakes. gl tho
Old Apr 7, 2011 | 01:55 AM
pricojorge's Avatar
i had a Similar problem except with the engine light
took it to the dealer, they resetted the ECU and runs great now ..
Mry
Mar 3, 2023 01:03 AM
SiMpLyMoDiFiEd
The FX-Spot
Dec 2, 2021 04:35 PM
JermaineSanders
Aug 18, 2015 08:57 PM
Wayne9011
Aug 17, 2015 01:24 AM
Wayne9011
Jul 27, 2015 11:25 AM
