Spark Plugs Recommendation
Old Apr 15, 2011 | 03:05 PM
rdeol's Avatar
Hi Guys,
I would like to change out my sparkplugs. I have 80k kms. I know they aren't recommended yet but I would feel a lot better to replace them now.
I was wondering what brand/type do you recommend for a 2007 G35s Sedan and where do you usually buy them from. I'm from Canada and would be looking at a place in the US close to Vancouver or even having them shipped to a US address.
Thanks!
Old Apr 15, 2011 | 09:32 PM
rdeol's Avatar
Bump!
Anyone!
Old Apr 15, 2011 | 10:06 PM
max2's Avatar
Hey, I'm new here so hope it's okay to post links to other forums. Here is the info you need:
http://forums.nicoclub.com/how-to-ch...7-t466365.html
Peace and happy wrenching.
Old Apr 15, 2011 | 10:13 PM
vqsmile's Avatar
Doesn't the Owner's Manual spec them? (or an under-hood sticker)
I would think either NGK or Denso Iridiums would be fine.
Old Apr 16, 2011 | 12:52 AM
kool_yaar's Avatar
ya in FSM its says DENSO iridiums with 1.1mm gap...
Old Apr 16, 2011 | 01:37 AM
rdeol's Avatar
Thanks for the help guys!
Where should I order them from? What's a good cheap place?
Here in Canada they want about $20 a piece!!!
Old Apr 17, 2011 | 09:44 AM
ampsucker's Avatar
try o'reilly automotive, pep boys, autozone, etc. you can probably even find them on eBay!
be sure to gap correctly and look over coil packs and connections well when installing. i like to use a little dielectric grease on the boots to keep moisture out and make a good connection.
also, be sure to use a calibrated torque wrench and torque the plugs to the correct spec. (which i don't know off the top of my head or would give to you =-)
Old Apr 17, 2011 | 02:13 PM
kool_yaar's Avatar
ya imp stuff, the DIY link has almost everything covered... "torque specs are 168 inch pounds or 14 foot pounds..."
Diode Dynamics
Accessories-Vendor
39
Nov 30, 2021 02:28 PM
Vqalexisz
Oct 14, 2015 12:48 AM
JustinMKN1
Sep 18, 2015 03:40 PM
twentyeggs
Sep 11, 2015 03:58 PM
pdexta
Tuner & Dyno
Sep 2, 2015 01:03 PM
