Help with M45 19 rims
Old May 14, 2011 | 06:20 PM
  #31
Geemy's Avatar
No drop no spacers on AWD susp. =D
Wheels are for sale in the 19'' section btw =D
Old May 14, 2011 | 06:25 PM
  #32
Geemy's Avatar
double post sorry
Old May 14, 2011 | 09:26 PM
  #33
makeinu0's Avatar
Mishmosh: Sorry I sent you a message for same question :-P my bad....
Geemy: The setup is dope. Mines dropped with H-tech right now and I know i gotta get spacers or it's gonna look retarded.... but I'm not sure which lugs Im suppose to get. There's so many people on the forum that's using spacers, so I know its not impossible to find (unless everyone's just using OEM lugs w/spacers), just need some hints for this.... :-(
Old May 14, 2011 | 09:52 PM
  #34
mishmosh's Avatar
These spacers require replacing the stock lugs with longer ones. This is no small remove and replace--trust me!
This is an installed spacer (ichiba v2) with built in studs that attach via the stock lugs. Notice that the stock lugs protrude past the spacer. Your rim must have cavities in the spaces without holes for this to work. M45 rims have this.
If you are on stock suspension, why don't you mount the wheels/tires first to see if the look is to your liking. My car is dropped on Eibach springs and it looked ridiculous without spacers. I have 15mm spacers but some have 20mm (or even 25mm) with Eibach. On a stock suspension, some have recommended 15mm spacers for the m45 rims.
Old May 16, 2011 | 11:12 AM
  #35
makeinu0's Avatar
hey thanks a lot mish, I really appreciate all the help from you. I ordered the H&R spacers 15mm.
Old May 16, 2011 | 12:45 PM
  #36
makeinu0's Avatar
One last question....
Center bore would be 66.1 or 66.2mm?? I searched on different sites and it seems to be mixed.
Old Feb 9, 2012 | 02:29 PM
  #37
matts08x's Avatar
Geemy, your car looks phenomenal with that set up....does anyone have pics of their 2nd generation X with these wheels and also dropped with H & R springs? Thanks!
dseet
Oct 11, 2015 12:40 AM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
dcsbh1
Oct 1, 2015 03:15 PM
Patrick Bovee
Oct 1, 2015 10:42 AM
inexorable
17 Inch
Sep 24, 2015 10:43 AM
