rolling rolling
Old May 13, 2011 | 10:03 PM
Christopher112's Avatar
rolling rolling
Hi-
I have a 07 g35x and am thinking of getting 19x9.5 et 33 wheels all around with 245/40/19 tires. I was toying with lowering on Tanabe nf210 springs. I was wondering if you think I will need to roll my fenders? I really rather not have to touch the fenders and just want a nice wheel/spring setup. Are the wheels to wide or the offset to aggressive to not need to roll the fenders? I do have people in my back seat rather often and don't want to have to worry about to much weight and having my tires rub.. any thoughts?
Thanks,
Chris
Old May 13, 2011 | 10:13 PM
kool_yaar's Avatar
07+ G35/37 come with factory pre-rolled rear fenders check em out. u should be fine with 9.5 but 33 might be a bit too aggressive... chk this car out he has 9.5" +34 rear and it seems to be right on the edge. But they might fit, someone with a definite answer should pop in and help you out soon.
Chk out this sticky for all possible combinations with offsets that fit and pics here
Old May 13, 2011 | 10:23 PM
broke_as_ajoke's Avatar
based on the pic of that other dudes car.. if u put (heavy) stuff in ya trunk and big folks in ya car u will need to roll your fenders in the rear.. that car in the pic is sitting close to the fender
Old May 13, 2011 | 10:26 PM
I hear ya, but I'm basing my numbers off of this car http://myg37.com/forums/picture-shar...hotoshoot.html
Those are actually the rims I want to get with a slightly different drop.. Only difference is he has a g37.. He says he doesn't rub or have his fenders roll, but I want to make sure thats not just a fluke..
Old May 13, 2011 | 10:32 PM
kool_yaar's Avatar
Originally Posted by kool_yaar
07+ G35/37 come with factory pre-rolled rear fenders check em out. ...
again rear are fully rolled and a bit pulled even on 2nd gens, if anything you can pull em some more but i doubt that itll look good...
Old May 13, 2011 | 10:38 PM
tpc303's Avatar
^ +1
Old May 13, 2011 | 10:39 PM
how about the fronts? Do they generally clear a little easier if I am going with the same size all around?
Old May 14, 2011 | 04:29 PM
So are there any other opinions? I just want to make sure these will fit without issue, and I can't afford to buy the wrong rims.
Thanks
Old May 23, 2011 | 08:30 AM
GXXXV X's Avatar
I think 9.5 might barely fit the front, might be a bit wide actually
Dallsinghjr1
Sep 17, 2023 11:25 AM
DRG35R
Jan 31, 2016 07:14 AM
dcsbh1
Oct 1, 2015 03:15 PM
NyCrAzY
Oct 1, 2015 09:19 AM
ncg35guy
Sep 26, 2015 04:04 PM
