What is this light
Old 06-08-2011, 05:21 PM
pricojorge's Avatar
What is this light
It turned on me while waiting at the light. And I don't have a manual at home, so can someone tell me please and thank you. I'm guessing coolant but I wanna be sure
Old 06-08-2011, 05:24 PM
grocerylist's Avatar
low tire pressure
Old 06-08-2011, 05:27 PM
pricojorge's Avatar
Originally Posted by grocerylist
low tire pressure
Ohhhh ! Thank you I didn't know I had those sensors 0.0 thanks
I appreciate it
Old 06-08-2011, 05:46 PM
GeeWillikers's Avatar
Walking The Fine Line...
Yep - TPMS.
Bad news is it might not mean a tire is low. I have one that comes on when the tires get warm and I don't have a pressure issue. I have a bad TPMS..
Old 06-08-2011, 05:49 PM
Geemy's Avatar
I think they blink when the pressure is low, if it stays on constantly means that a TPMS is defective or needs to be activated.
Old 06-08-2011, 05:58 PM
pricojorge's Avatar
Damn it stayed on
No flashing =\
Old 06-08-2011, 06:02 PM
bluedevils95's Avatar
I think this light is a waist of time. When i had my stock wheels, that light only came on when the TPMS sensor was broken.
Old 06-08-2011, 06:05 PM
vqsmile's Avatar
Mine don't do that. They stay steady and my sensors apparently work just fine.
Originally Posted by pricojorge
Damn it stayed on
No flashing =\
Unless you find one significantly lower than all the rest (and indicating a clear problem), try setting all your tires to around 38 lbs. and drive it a while to see if it goes away. Sometimes they don't reset right away if you set them right to the exact pressure, so I usually overshoot them all for a day or so until the light goes out, then I reset the pressure down to spec. This typically happens at the start of winter when it gets cold, or else when I've had a leak.
Old 06-08-2011, 06:09 PM
vqsmile's Avatar
BTW, I have to say it's rather funny (and perhaps a sign of the our culture these days) that the OP took the time to photograph the problem and post in online and wait for a response, when he could have download an Owner's Manual (for free) in less time and looked it up himself
Old 06-08-2011, 06:22 PM
pricojorge's Avatar
I'm at work can't really do much from my phone. Where can I get the manual online ?
And I went out to check and yes found one that was low going to fill it once it get home at 1am lol
Old 06-08-2011, 06:30 PM
jcrayamsterdam's Avatar
I'm in Canada and swap in tires on plain rims in the winter. I don't have TPMS sensors on that set of wheels. The light flashes for the first minute or so after an engine start and then stays steady for the rest of the trip.
Not sure what it does when pressure is low.
J
Old 06-08-2011, 06:38 PM
vqsmile's Avatar
Make a screen name and you're set. You can also download the FSM for free too.
http://x.infinitihelp.com/forum/loca...s.php?catid=56
Old 06-08-2011, 06:47 PM
rpm&my_G35's Avatar
Here...have a copy of mine...no need to sign up although infinitihelp is a good place to get a lot of important service bulletin info. You should sign up.
Old 06-08-2011, 07:12 PM
salvador312's Avatar
I hate that light, I have aftermarket wheels and I don't have TPMS. Maybe I'll get some one day!
Old 06-08-2011, 07:31 PM
RedBaronK's Avatar
Wow... we have the exact same avg miles per gallon.. mine is 18.5 too so far with 38k miles
Quick Reply: What is this light
