Need your opinion on rotors!
It's only removed from the heavy side, whereas with wheel balancing, you add weight to the lighter side. It was most likely performed after the blanks were drilled and slotted. I have to say that it doesn't reflect well on the quality of the rotors to have so much material milled off to achieve proper balance.
I'd say stick to OEM. If you want better braking power, upgrade your lines, pads, and fluid. Unless you're racing your car, you don't need slotted or drilled rotors. They're only going to decrease your pads' life.
Or, if you're into the looks of it... I guess you can get those.
10, brakemotive, brakeoverstockcom, brakes, code, coupon, g35, g35driver, infiniti, infinity, option, performance, promotional, review, reviews, rotor
