Painting your window switch panels.
Old 08-09-2011 | 09:05 PM
kool_yaar's Avatar
^ how much are they gonna charge you for doing the entire headliner and pillars black? my TL-S has this black headliner and that is just beautiful!
  #62
Old 08-09-2011 | 09:36 PM
G35VSHNG37's Avatar
I never asked about the G since I planed on leaving it the color it is to break the color up a little. They did the b and c pillar in my z for 30 bucks a piece, i supplied the material which is still cheap. They did a great job too.
  #63
Old 08-09-2011 | 09:53 PM
salvador312's Avatar
There are a few people that done te headliner here! All by themselves! I thought about it before but sounds like a hard project!
  #64
Old 08-09-2011 | 09:57 PM
  #65
Old 08-09-2011 | 10:06 PM
bluedevils95's Avatar
You should have painted the air vents in the pillars! it would look better.
  #66
Old 08-09-2011 | 10:08 PM
If your in the LA area i might be able to point you in the right direction. I know 2 places that work on our cars. One has the better name.
  #67
Old 08-10-2011 | 11:13 AM
G35VSHNG37's Avatar
It actually looks really good in person with the unpainted vents. The vents offset the black just right....to me at least..I might do them though..
  #68
Old 08-15-2011 | 09:17 PM
MPohio's Avatar
Front Bumper looks like crap
Ignore, wrong thread
  #69
Old 08-16-2011 | 10:51 PM
altimamark's Avatar
I used 3M 400 grit sand paper wet sanded surface , then rinsed with mild detergent let dry then applied several coats of Dupli- color vinyl & fabric flat black spray paint. Came out perfect. Remember when removing switch bezel be careful not to break tabs off from bezel . I used a nylon tool ,used for removing trim witch was done from the inside of seam of handle grip instead of outside not to mar plastic edge. Take your time.
Attached Thumbnails Painting your window switch panels.-photo_9b252119-8b87-cd84-f8e0-d2821d86746a-1-.jpg
  #70
Old 08-17-2011 | 03:29 AM
I color matched mine vents to my car.
  #71
Old 08-19-2011 | 10:17 PM
phorvic's Avatar
NIce write up
  #72
Old 08-20-2011 | 05:14 AM
MaximaZero's Avatar
I'm in the middle of doing this myself except my interior is stone, not black. The closest match I found was Rustoleum Painter's Touch Satin Stone Grey. It's about a 95% match and you can only really notice the slight difference in bright sunlight. Still an improvement over how beat up looking it was before.
  #73
Old 08-21-2011 | 04:57 PM
Are you going to post pix when your done?
  #74
Old 09-13-2011 | 11:00 PM
VincenzG35's Avatar
I'd CF wrap em guess I'm lucky mine came black
  #75
Old 10-09-2013 | 02:07 PM
HeyItsFranklin's Avatar
Sticky to DIY section please.
jilljann1
07-21-2020 09:12 AM
linedr89
Engine - Power Adders
10-04-2015 08:29 PM
cmesidewayz
09-29-2015 10:28 PM
TwinTurboZ
19 Inch
09-26-2015 07:11 PM
