Add factory options
Old Aug 17, 2011 | 03:01 PM
Dale07's Avatar
Add factory options
So when I got the car I didnt know there were so many packages, or what came with what.
What I did realize when I got the car is that I was giving up heated seats and auto dimming rear view. Now that I'm here and know about a few things, I'm wanting to see if I can add options.
Now, having owned a mopar product before, I know they make a few wire harness and its easy to bolt it, and plug in the electrical. I added alot of options the truck didnt come with. GM on the other hand makes a bazillion different harness and you get no extra wiring making it a pita to add an option.
So, particulars I would like to add heated seats, rear view, maybe the bose stereo option, and make it so I can roll all 4 windows up with the remote, rather then 2. Rear view camera would be nice, but Ive seen how to do that aftermarket on here.
How easy would this be to add? Did Nissan/Infinity leave the wiring in to easily add these?
Old Aug 17, 2011 | 04:16 PM
pricojorge's Avatar
ehhh
not really easy to do
can be done for sure but might give up, infiniti doesnt leave wires around, except the ones i know, which is paddles and xm radio.
Old Aug 17, 2011 | 05:01 PM
Dale07's Avatar
The xm option would be nice But I gotta drill a hole for the antenna correct?
Old Aug 17, 2011 | 05:59 PM
Rollo's Avatar
I added XM to my last car and left the antenna in the rear window with no issues so the answer is no, you don't have to drill a hole in the roof--if that's what you are implying.
Old Aug 18, 2011 | 07:48 AM
Dale07's Avatar
oh, the antenna is not mounted on the roof? SWEET. Is there a writeup on here how to do this with factory items?
Old Aug 18, 2011 | 09:20 AM
eatsleepdrum's Avatar
awwwwww
Old Aug 18, 2011 | 11:40 AM
Dale07's Avatar
Ok, I'm more awake now. So your saying you just laid the roof antenna in your backglass and it worked. But to do it right, I need to drill a hole :/
Old Aug 18, 2011 | 01:49 PM
Rollo's Avatar
If "do it right" means putting a shark fin on your roof then I guess you would need to drill a hole.
I had it installed in on my BMW 330i back in 2007 and the antenna has been in the back glass area since installation and has always worked perfectly.
Unless you plan to install the shark fin cover I would not advise drilling any holes.
Option packages make a big difference in this car in my opinion--good luck in getting those upgrades done...
Old Aug 18, 2011 | 02:14 PM
rvanderwerf's Avatar
Anyone try adding ICC?
KruZZe
Feb 27, 2023 05:04 PM
prinny
Nov 22, 2015 11:07 PM
9tray turbo
Sep 29, 2015 10:22 PM
TurTLe*
Sep 29, 2015 01:43 PM
