A/T grounding point?
"Extra grounding" means adding more ground wires to ease the flow of electrons from components to the chassis. The battery and the engine are factory grounded but they are not sufficient. That is why grounding kits are used. One cable is not enough in my setup. The engine needs some help and the battery does too. If you do a little research on ground kit, you will see they are selling ground kit with 8-12 wires. Again, in my opinion, 2 wires are enough no more no less.
Maybe I didn't say it clearly. I asked for a grounding point on the transmission on this thread but ended up not doing it. I ordered 2 cables and installed one on the battery, the other on the engine. I did not add any wire on the transmission and will not consider doing it since I already got decent shifting.
