Fitment gurus...need help 25+ offest on 10 inch wide wheel
Old 09-07-2011 | 05:50 PM
Boostd1's Avatar
^^^ Pics?
  #32
Old 09-07-2011 | 06:05 PM
iiiiiekoiiiii's Avatar
credit card clears it... llolz
  #33
Old 09-07-2011 | 06:18 PM
Boostd1's Avatar
I have an 07x
  #34
Old 09-07-2011 | 06:53 PM
sunny G-35 NYC's Avatar
I have eibach springs for sale. I had them on my car for about 15,000 miles only $ 85. Pm me if your interested and well see what we can do for shipping
  #35
Old 09-07-2011 | 07:01 PM
sedan fender clearances are about the same for the rears...
I know cause my old rims are on a 2011 g37xs sedan... same fitment...
  #36
Old 09-07-2011 | 08:35 PM
Boostd1's Avatar
So lowering the car on Eibachs will defentily suck the wheel into the fender with just putting in the springs? The wheel sticks out a good amount right now...
  #37
Old 09-07-2011 | 10:54 PM
it would make it flush with a 245/35 tire
  #38
Old 09-11-2011 | 01:55 PM
Eibachs... I dont know. theyre weak drop... I know for a fact coupe H&Rs on the sedan will do the job, but you will be low as me on springs... lol not my favorite ride.
  #39
Old 09-12-2011 | 08:38 AM
G35VSHNG37's Avatar
I am currently on 18x10 +25s all around, 255/35 and 265/35 in the back. looks great but its no 20.
  #40
Old 09-12-2011 | 10:07 AM
GXXXV X's Avatar
Originally Posted by apexi957
You'll be fine.
I'm doing a 19x10 all around with +30F and +25R with a 245/35/19 all around.
I don't mean to thread jack but do you rub at all? Im thinking of doing the same setup, except with +22 offset...would that still work?
  #41
Old 09-12-2011 | 01:52 PM
ttv36's Avatar
Originally Posted by iiiiiekoiiiii
just lower your car. you'll be fine running 245/35/20s for the clearance...
Lower you go more you tuck the wheels in...
Im running 20x10.5 +25 offset with 275/30/20s Slammed on coilovers...
I don't know how you do it. I am on 9.5 +34 rear and -1.7 camber with 275s and rub on large dips in the road. Your setup is +22mm more than what I'm running now! Props man.
Edit: Perhaps it's the extra inch of width that gives you a slight stretch?
  #42
Old 09-18-2011 | 03:13 PM
Extra inch only makes it worse lol
maybe your problem is too wide on 9.5 tire so sidewalls become bubble. if you look at my pix, 275 nankang side walls curve in, due to Nankangs running a little small.
I maxed out bc coils in the rear on 200mm springs, and raised maybe a finger gap higher on 20s now, but it sits at u see in the pix.
I know im running a lot more camber then 1.7 tho. Its all natural camber from slammage. my camber kit is sitting in my trunk for the past year lol
  #43
Old 09-18-2011 | 09:58 PM
snapped a pic at a gas station...
20x10.5 +25 (20mmspacer) 275/30/20
  #44
Old 09-18-2011 | 10:01 PM
CandlestickPark's Avatar
ill Sedan
I wouldn't even consider running this setup on Eibach springs. You need coilovers and you need a nice drop (no fender/tire gap, but preferably tucking tire).
obender66
18 Inch
03-13-2016 12:20 PM
CJay
08-01-2015 03:57 AM
IEMaestro
20 Inch
07-30-2015 04:30 PM
Soumilg
07-18-2015 12:33 PM
EasySausage
07-14-2015 11:17 PM
Quick Reply: Fitment gurus...need help 25+ offest on 10 inch wide wheel
