Condensation in headlight
Old Sep 5, 2011 | 04:59 PM
Greenlawnracing's Avatar
I've got quite a bit I just noticed......car has been sitting in the garage since last night.
Warranty item?
Old Sep 5, 2011 | 05:24 PM
gtbigup01's Avatar
Probably not, but it doesn't hurt to ask them.
Old Sep 5, 2011 | 05:26 PM
Assuming it isn't, how does one address this?
Old Sep 5, 2011 | 05:32 PM
gtbigup01's Avatar
It'll fix itself. It's not a perfectly air tight system like say and aircraft (747), so temp changes will allow this to happen. What yr is your car BTW?
Old Sep 5, 2011 | 05:51 PM
08 6mt
Old Sep 5, 2011 | 06:02 PM
GXXXV X's Avatar
if it doesnt fix itself, you could probably just take the bulbs out/unplug them and let the housing air out for a while
Old Sep 5, 2011 | 08:27 PM
pattyballs's Avatar
I would leave it for a few days, i had this happen to my passenger side headlight on an extremely hot day and within a day or so it was gone.
Old Sep 5, 2011 | 09:14 PM
kool_yaar's Avatar
^ what he said our lights are not air tight and have a vent it should go away in a few days in warm temps
Old Sep 6, 2011 | 12:38 AM
vqsmile's Avatar
Doesn't just the heat from using them dry them? Do you actually use them much?
Old Sep 6, 2011 | 09:31 AM
blkdragn's Avatar
I've noticed that during drastic temp changes for example like from being very hot and immediately cooled with cold water or vice versa.
If it doesn't "fix" itself, you can also reseal them with this:
http://www.theretrofitsource.com/pro...roducts_id=792
You might want to think about painting/upgrading while it's all apart too.
Old Sep 6, 2011 | 10:07 AM
Wannabe6MT's Avatar
-MN G Crew-
Mine do this after a wash.... hmm
Old Sep 6, 2011 | 07:49 PM
Took it in to the stealership today because I had some hail damaged recently repaired. Window tint got scratched, BT mic isn't picking up, and the tire gel they used won't come off my mud flaps.
Asked them about the headlights while I was there....they said they took them off to service the hood, but they weren't opened. Thought it would be a service item and will get back to me.
Odd that they gave me an 07 Pontiac Grand Prix with heavy hail damage and a low oil light for a loaner.
jeffbdye
Jun 1, 2018 03:51 PM
Picture Share
Feb 4, 2018 12:41 PM
9tray turbo
Sep 29, 2015 10:22 PM
Batfinity
Lights
Sep 27, 2015 12:29 AM
